A Mirror that is used for smaller coimmercial bathrooms |
17012 downloads
Wall-Hosted family. Curved grab bar for ADA shoower. Can be mirrored into position if needed. Fully adjustable w/ pull arrows. |
6692 downloads
Based on ASI 8205. Seat is not parametric. Built to nest in a stall shower of a given size. Width and depth dimensions correspond to shower stall width and depth so the seat positions correctly in the corner. |
28103 downloads
No rating |
Product Version: Unknown
4800 downloads
No rating |
4478 downloads
Hand Towel Ring |
Product Version: Revit Building 9.1
6204 downloads
This a fully parametric medicine cabinet. Everything can be controlled including the door swing direction, materials, and size. |
7846 downloads
Symbolic, based from the series offered by Freedom. This is a rectangular phenolic seat that can fold into the wall. Only the slat are 3D, the rest is just symbolic lines to look at something in elevation. |
2239 downloads
There is a material for the fabric and also a material for the metal.
The height of the curtain can be adjusted on the base and also on the top.
The rod height is also adjustable, I think.
The curtain is stationary - you cannot close it.
The flanges can be adjusted away from the wall or set it to "0" to be flush with the wall. |
69995 downloads
*Modified from previous content uploaded by vaamarieta.
The flanges are no longer adjusted away from the wall, but set to "0" to be flush with the wall. |
12812 downloads
Parametric Soap and hand sanitizer dispenser. Items can be placed separately. |
7473 downloads
No rating |
1067 downloads
No rating |
3668 downloads
