83 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 3 | 1 | 2 | 3 Next >>
10 - Toilet Accessory - Sanitary Napkin Disposal
3.5 Stars from 2 Votes
Product Version: Revit Building 9
20114 downloads
3D Grab Bar w/ Vertical
Product Version: Revit Building 9.1
1767 downloads
ADA Corner Grab Rail for Toilet
Stainless Steel Grab Rail
Product Version: Unknown
15948 downloads
ADA Grab Bar
ADA Grab Bar
ADA Grab Bar
3.5 Stars from 4 Votes
26888 downloads
ADA Handrails
ADA Handrails
ADA Handrails
14501 downloads
ADA toilet grab bars
Includes horizontal side bar, vertical side bar, and back grab bar (behind the toilet). Fully adjustable lengths and mounting heights.
2 Stars from 3 Votes
21858 downloads
Bathroom Vending Dispenser
3937 downloads
wall mounted
4683 downloads
4495 downloads
Bobrick B-3471
Sanitary napkin and toilet paper dispenser two sided thru wall with partition thikness parameter
1903 downloads
BOBRICK B-43944 SEMI-RECESSED TOWEL DISPENSER & WASTE RECEPTACLE
BOBRICK B-43944 SEMI-RECESSED TOWEL DISPENSER & WASTE RECEPTACLE WITH CORRECT PROPORTIONS & MASK REGION TO COVER WALL PATTERNS IN SPACE BETWEEN UPPER AND LOWER SECTIONS.
4 Stars from 1 Votes
2953 downloads
Bobrick B-68137 Two-wall wheelchair compartment grab bar
This is a Bobrick model #B-68137 two-wall wheelchair compartment grab bar.  It was derived from the Bobrick specificaion sheet (URL noted in Family) and is wall based.
4722 downloads
Bobrick B505 Pass-thru
Pass-thru based on Bobrick B505 specifications. Family set up to allow for right, left and opposite door swings, and should accomodate veriying wall thicknesses. Enjoy
4090 downloads
Bobrick Paper Towel Dispenser - B-3944
this family is not extremely detailed but is perfect for plan and elevation views. It represents the exact dimensions of the Bobrick B-3944 paper towel dispenser.
1 Stars from 1 Votes
7287 downloads
Bobrick Soap Dispenser - B-40
this family is not extremely detailed but is perfect for plan and elevation views. It represents the exact dimensions of the Bobrick B-40 soap dispenser.
5563 downloads
Bobrick Toilet Paper Dispenser B-2888
this family is not extremely detailed but is perfect for plan and elevation views. It represents the exact dimensions of the Bobrick B-2888 toilet paper dispenser.
16940 downloads
CWS Stainless Steel Paperroll - BIMobject
Download: http://bimobject.com/en/cws-boco/product/7205000
This is an example of one of the many objects available from this manufacturer on the BIMobject Cloud. Click on the link to find so many more objects which are free for all designers from around the world to use. We also have an amazing app which enables you to access our complete library directly from within your BIM software
Revit app: http://info.bimobject.com/revit-app
Paradise Stainless Steel Paperroll roll paper hand towel dispenser for 100 m of paper roll, 22 cm wide. Paper can be removed in sections measuring approx. 25 cm (easy pull-out). Automatic cutting system with protective cover to prevent injury. Next section fed to within reach. "Easy-Loading" system for quick filling. Housing including rear wall made of matt brushed stainless steel 1.4301, brushed satin finish protects against fingerprints, with lock. Rounded edges ensure no risk of injury. Comes complete with fastening materials, delivery and installation.
Dispenser:
Stainless Steel Paperroll: 7205000
Roll paper:
white, 100m, 3-ply: 288001, blue, 100m, 3-ply: 289000
6128 downloads
Dual Toilet Paper Dispenser - Bobrick B-2840
2 Stars from 1 Votes
7520 downloads
Grab Bar - 1 Straight Piece
7378 downloads
Grab Bar - 2 Straight Pieces
5459 downloads
Grab Bar - L-Shaped Piece
2462 downloads
Grab Bar Pull Down 3d
Pull Down Grab Bar modified to host correctly on wall face
4331 downloads
Grab Bars - Toilet
Grab Bars - Toilet
Grab bars for Toilet meeting ANSI Type A requirements.
3 Stars from 3 Votes
41505 downloads
Grab Bars-Continuous
ADA Grab Bars-Continuous
1232 downloads
Model is based on the B-2112 (ClassicSeries) Surface-Mounted Soap Dispenser
3521 downloads
3191 downloads
wall recessed
1639 downloads
wall recessed
1783 downloads
wall recessed
1610 downloads
wall recessed
2601 downloads
Page generation time: 0.6289
