Simple armchair made from an extrusion and lines. Perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator. The beam is offset to counter line clipping through the table top surface. |
No rating |
1917 downloads
Arm Chair Vime |
No rating |
10429 downloads
Armless_Task_Chair (Non-parametric) |
No rating |
5453 downloads
Modern bar stool |
25810 downloads
generic kitchen stool |
No rating |
4305 downloads
This is a Revit model of a bar stool that a designer named Miles Endo created on Ellen's Design Challenge. I loved the look of this piece so much that I had to create it on Revit. The materials should be fairly easy to change if you'd prefer a different type of wood. This is my first upload, so I'm sorry if it isn't perfect. Any feedback you might have would be wonderful. Sorry for anybody using an earlier version of Revit! |
1151 downloads
Hey this is something that i still had before they upgraded to Revit 09 |
No rating |
Product Version: Revit Structure 2008
1835 downloads
Afternoon one and all.
Been a few weeks since my last upload so heres your treat for today.
This stool is modelled on the Bride’s Veil Bar & Counter Stool.
Link to the stool below and also found within the URL properties within the family.
http://www.phasedesignonline.com/content/portfolio-item/brides-veil-bar-counter-stool/#!prettyPhoto
2 main parameters on this, seat and frame.
I've not given the seat the actual fabric, i've just assigned it a standard fabric otherwise it will loose the image file on upload.
Have fun |
5361 downloads
I EXPORT 3DMAX TO DXF THEN IMPORT TO REVIT ASSING MATS..
I ACCEPT CONSTRUCTED COMMENTARIES AND RECOMMENDATIONS.
PD I DONT MODEL CHAIR |
7974 downloads
Soft edges-simple geometry |
No rating |
4533 downloads
No rating |
989 downloads
Chaise lounge lawn chair. |
Product Version: Unknown
38022 downloads
a stool i designed based off the "designer chair". materials have been applied, but can be changed |
11667 downloads
Autoprogettazione |
468 downloads
Autoprogettazione |
322 downloads
Autoprogettazione |
293 downloads
For some reason I can't update this file but you will notice the back appears to be missing if you are in course or medium detail level in your project. This is easily corrected in the family element visibility settings or just make sure your project view is set to fine detail level.
And for anyone that doesn't know how to place a face-based family in your project go here...
For more great, high quality Revit components go HERE! |
6502 downloads
No rating |
8423 downloads
My recreation of the Herman Miller Magis Spun Chair.
Material can be set.
Please rate and comment! Thanks. |
773 downloads
Timber deck chair with parameters for finishes, Revit based. |
45528 downloads
This is a recreation of the Austin swivel chair from King Hickory furniture. Non-para. Materials can be set for body, seat, and seat back.
I made this for my wife who is an interior design student. Hopefully it helps some others out there. |
No rating |
1554 downloads
Model of the Fairfax chair by Kelly Wearstler.
Non parametric. Materials can be set for the body pieces combined. There are a couple minor incongruencies that I was unable to resolve dealing with the cutout in the lower portion of the chair. Hopefully it doesn't cause any problems.
I made this for my wife who is and interior design student. I hope it helps some others out there. |
No rating |
8858 downloads
13592 downloads
No rating |
6800 downloads
13897 downloads
Designed by Urbia
Stool is Parametric
Material is determined by type
Standard size is 15.25" Diameter, 18.25" Height
801 downloads
5853 downloads
Hello everyone, its been a while.
Here is a nice Modern Style dome seat for that finishing touch.
Fixed in size but 2 material parameters, Main body material and grey leather fabric. NOTE that the grey leather has been downloaded from the link below. I change the overall pixel resolution as it was too big when downloaded. I used 200x150 if that helps.
https://crackberry.com/sites/crackberry.com/files/styles/w325/public/images/wallpaper_20080516044959_13387878332.jpg?itok=sz_-NkSj
Hope it comes in useful.
Enjoy |
No rating |
2803 downloads
M_Curtain Wall Sgl Glass |
No rating |
2345 downloads
My best recreation of the Butte Chair from Old Hickory Furniture. Non-para.
Made it for my wife who's an interior design student. Hopefully it helps some other people out there. |
No rating |
1332 downloads
