FULL SIZING AND MATERIAL PARAMETERS. FACE-BASED SO CAN BE PLACED ON ANY SURFACE. REVIT 2025. |
No rating |
26 downloads
Material: Polyester Fabric material, Vinyl Plastisol end caps and a Polypropylene core
Operating Temperature: 4oC to 50oC
Maximum Pressure Drop: 20 kPa
No rating |
Product Version: Unknown
385 downloads
Circular Clothes Rack |
No rating |
5308 downloads
Clothes Rack |
49757 downloads
Product Version: Revit MEP 2013
5724 downloads
Display Case |
Product Version: Revit Building 5.1
38818 downloads
wood with frosted glass |
9704 downloads
A stainless steel Chefs table made by Duke Industries. 60"x30" kitchen work table made to specs. Parameter for material. Will make other sizes by request. Please rate and comment. |
10382 downloads
1300mm x 1600mm fuel tank. thankyou habibi. muah kit |
No rating |
1424 downloads
No rating |
698 downloads
two sided |
11390 downloads
one sided |
7647 downloads
end gondola |
No rating |
1859 downloads
this is a 450mmX900mmX1500mm sales gondola with parametric material finish to suit your preferred color. |
5322 downloads
GONDOLA FLOOR DISPLAY RACK - CHAIN LINX |
No rating |
2830 downloads
GONDOLA FLOOR RACK WITH SHELVES EACH END BY CHAIN LINX |
8851 downloads
A Migali G3 series commercial fridge or freezer. Both are identical in appearance so only one is needed. Parameters are set for materials but I made it from their specs and documents so it is exact in every way. Please rate and comment. |
29684 downloads
Registradora se supermercado compuesta por la cabina junto con la cinta transportadora, escaner y pantalla de informaciĆ³n |
No rating |
Product Version: Revit Architecture 2019
323 downloads
369 downloads
Gate and seat can be shown open or folded for stacking.Revit 2016. |
13867 downloads
All dimensions and materials are parametric.
Start/End Angle - allows to specify appropriate sector.
Rin = Radius inner
Hdesk = Height of the desk surface from the floor
Wdesk = Width of desk surface
Tdesk = Thickness of desktop
Shelf = width of the shelf (from desk edge to show-surface)
Tleg = Thickness of legs
Tlb = Thickness of legs bottom
Hshow = Height of glass showcase
Hpan = Height of decorative panel |
No rating |
4756 downloads
Parametric are all dimensions and materials.
Layout type - horizontal. |
3926 downloads
Layout type - vertical. |
4168 downloads
A Steam Table with circular tops, a sneeze guard and storage area underneath. All pieces have parameters to control the materials. Please rate and comment. |
4640 downloads
A steam table with rectangular tops and space for plating. Every piece has a parameter to control the material. Please rate and comment. |
2943 downloads
Revit 2016. |
2135 downloads
Generic Tablet Base Cash Register With Credit Card Swipe, no cash drawer and non-parametric. |
No rating |
22060 downloads
I couldn't find a vending machine that looks good in renderings, so I made my own.
To get the snacks to show up in the machine, click here and download the image. Find the material called "Vending Snacks" and replace the missing image with this.
Made in Revit 2019 |
41077 downloads
I made this as a floor based model but it is meant to be on top of something. I put a bunch of parameters for materials, mechanical loads, specs, etc. This was built to vulcans specs. Please rate and comment. |
Product Version: Revit MEP 2010
4559 downloads
