14,000lb. Four-Post Vehicle Lift |
Product Version: Revit Building 9.1
11925 downloads
Old Chevy Caprice with 30" Rims, wowza!!!
Enjoy!!! |
4432 downloads
Portable aircraft tripod assembly used for supporting airplanes while being serviced. Usually three assemblies are used per plane. Length of piston is adjustable to suit the various support heights. |
No rating |
Product Version: Unknown
1613 downloads
This is a basic parklift patterned from Wohr parklift 440. Feel free to edit for I am not that sure with the 3d components; but this is a good framework, though. Hope to update soon. |
No rating |
1622 downloads
No rating |
2426 downloads
Camper Van
Modded off of an existing van on this site. Very basic but it did what I needed.
Modify further if you wish. Materials are basic also.
RevitLT 2018 |
4632 downloads
11624 downloads
Car Lift |
25509 downloads
Coats Tire Changer (unsure of model #, this was modeled from an existing to remain piece of equipment in a project) |
No rating |
1786 downloads
Crane with a lot of parameters |
No rating |
732 downloads
Engine Crane - Someone requested this so I hope it helps.
FILE TYPE: Revit 2012 64 bit |
5909 downloads
14927 downloads
Typical work truck with a toolbox and headache rack, sorry this truck does not have an interior.
Feel free to render as your tastes would desire.
Enjoy and please rate! :) |
19617 downloads
Graco Model XD30 High Capacity Hose Reel. Non face-based model Used in applications requiring long range dispensing of automotive fluids. |
No rating |
1044 downloads
Guindaste com vários parametros. Giros hor e ver, lanças, patolas, lançada e recolhida.
Crane with a lot of parameters.
No rating |
279 downloads
No rating |
804 downloads
A motor cycle lift i designed for a class project. Modeled after the modern blue and yellow schemes. Take it or leave haha |
7242 downloads
An Cylindrical Oil Catch with A Drain on The Bottom |
No rating |
Product Version: Revit MEP 2017
346 downloads
Passenger airliner with dual wing mounted jet engines |
Product Version: Revit Building 5.1
5689 downloads
Large passenger bus |
15980 downloads
No rating |
8408 downloads
3271 downloads
Snap-On Creeper - Great for Garage work and working under cars. Great for adding that extra detail to a project.
FILE TYPE: Revit 2012 64 Bit |
No rating |
2127 downloads
Steering wheel with Seat, materials are all editable
Enjoy!!! |
No rating |
845 downloads
Trailer I designed using some of Tiny Homes figures. Everything is able to be rendered differently to suit your tastes. ENJOY! |
3777 downloads
Created for a state maintenance facility project. Pretty standard tire rack... 72"H x 72"W x 18"D |
No rating |
4792 downloads
sdsdsdasda |
No rating |
Product Version: Revit Structure 2020
48 downloads
sdsdsdasda |
No rating |
41 downloads
