3 Bike racks by Barco Products
http://www.barcoproducts.com/store/index2.asp?DEPARTMENT_ID=156
Modelled in Revit 2012 |
Product Version: Unknown
11025 downloads
No rating |
6758 downloads
No rating |
1889 downloads
This is a basement egress window well I modeled after failing to find anything suitable online. I modeled it after Rockwell's Elite Series in an 84" depth. It's a half-ellipse extrusion with the stairs modeled as extrusions and then a revolved void to carve away the back of the ellipse. It's nicer looking than the typical corrugated versions with a ladder. No materials have been assigned. It is not parametric. |
No rating |
2865 downloads
Basement Window Well based on Shape Products 36-in W x 50-in D x 48-in H |
No rating |
75 downloads
Parametric Batting Cage 60' to 70'
HCabral Creator |
No rating |
3453 downloads
This is a standard 12"x12" Bison paver, roof hosted, with parametric offset. Thought about adding the pedestals, but too many variables...each height would need to be instance-based...seemed fussy. K-I-S-S.
Map the (3) attached image files to the material, making sure to "link texture transforms".
...happy decking... |
5258 downloads
No rating |
731 downloads
No rating |
490 downloads
No rating |
916 downloads
No rating |
3485 downloads
No rating |
527 downloads
No rating |
504 downloads
Cart Corral |
No rating |
Product Version: Revit Building 5.1
1407 downloads
Cart Corral |
No rating |
2092 downloads
3964 downloads
Here it is folks, a Corinthian Column based on the one available here on RevitCity for so many years. But this one acts just like normal columns, with Base and Top level parameters to define the height, and the column itself scales properly based on that height.
Thanks to this blog post on how to make this work: http://domokurarchitects.blogspot.com/2013/01/revit-tip-scalable-model-family.html |
11994 downloads
R E V I T COMPONENTS, the #1 source for high-quality, parametric Revit® Families + R E V I T COMPONENTS BLOG, keep updated. |
1522 downloads
2054 downloads
2251 downloads
SR Smith Diving Platform |
1516 downloads
447 downloads
Facade/ Mullion family |
No rating |
1751 downloads
I have not seen anything like this everywhere I have looked. Therefore I decide to make one. Full mesh parameters. I have also done a fence with pole using curtain wall family which I have not posted yet but you may request for it. |
2196 downloads
Gold and slate fountain. 40 foot diameter. Because when you're knock, knock, knocking on heaven's door, this is what you'll see. |
No rating |
4110 downloads
This is a free-standing Key Drop off cabinet for a car dealership or some other business where you might drop off keys after hours. It is based on the KeyKeeper XL Withstand model. |
750 downloads
Generic Fypon Crosshead - FULLY PARAMETRIC |
No rating |
693 downloads
Steel anchoring fixture for glass panels in walls or railings |
No rating |
Product Version: Revit Building 9.1
5510 downloads
No rating |
6195 downloads
Rotating cloathes drying device. adjust height, & Radius size |
1369 downloads
