61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 1 |
Anchor - Flip-Up Type Roof Anchor
Flip-Up type Roof Anchor Tie-back for window washing & Maintence persoanl Saftey
1852 downloads
Anchor - Pier Type Roof Anchor
 Pier Type Roof Anchor Tieback for Window Washing & Maintanence personal Saftey
3245 downloads
Anchor Window Washer Tie-BackBolt
Stainless Steel Window Washers Tie Down Bolt. Generic Model with 2 Parametric lengths for Height above the level (Typically Roof) and below down to the steel beam level
1867 downloads
Chainlink fence
Chainlink fence
Fully parametric Chainlink fence. Works at any length.
1 Stars from 1 Votes
12368 downloads
Chainlink Fence - Updated
Updated parametric chainlink fence. Fixed an issue with post caps visibility parameter.
Added ability to slope fence using a 'delta elevation' parameter
4.5 Stars from 10 Votes
31165 downloads
Dock Bumper-Front.rfa
798 downloads
Generic Wall Based Awning
Square wall based awning with parameters.
Product Version: Unknown
2872 downloads
Kawneer 1600 Sunshade
This is a RAILING element.  To be honest, I wasn;t sure how (or if I could) export a railing as a family, so I attached a Revit file with the railing embedded.  This is the Kawneer 1600 Sunshade (brise soleil).  Enjoy
5 Stars from 4 Votes
12360 downloads
Louvered Shutter - Parametric
This is a complicated, parametric louvered shutter.  It may have some glitches, but please let me know so I can repair them.
There are three options for look.  The formula works such that it will see if you selected "Equal Panels" First, if not it will see if you selected "Square Panel" (top area square), and if not it will use the value for panel height entered.
The family will automatically adjust the louvers to the size of the opening.
Please rate, and let me know if you have an issue.
5 Stars from 2 Votes
15892 downloads
Pergola
Pergola
Four concrete columns hold up a wooden pergola.
Product Version: Revit MEP 2016
9439 downloads
Potted_Plant_3D
Potted_Plant_3D
Great as in indoor plant or a plant on a deck or balcony.
4 Stars from 6 Votes
43848 downloads
Scalloped Wood Fence
Parametric scalloped wooden fence with parmetric max/min height and length.  Non-parametric, but editable, are 4"x4" wood posts, 1"x6" boards, and 2"x4" horizontal supports.  Note some exact lengths throw an error - if so, just choose a slightly different length.
1205 downloads
Sloped Wood Fence
Sloped Wood Fence
Updated my original upload with the ability to slope the fence with a delta elevation parameter. Also added flip controls to change direction of the fence
5 Stars from 3 Votes
23785 downloads
Steel Awning
Steel Awning
Length & width adjustable parametric awning.
Product Version: Revit Building 9.1
22702 downloads
Sun Shading Device
Sun Shading Device
2" Air Foil with parametric width - wall based.
3 Stars from 1 Votes
5793 downloads
Wood Fence
Wood Fence
Line based parametric wood plank fence
5765 downloads
Page 1 of 1 |
Page generation time: 0.4079
