35 Users Online (34 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 4 | 1 | 2 | 3 | 4 Next >>
10 - Toilet Accessory - Sanitary Napkin Disposal
3.5 Stars from 2 Votes
Product Version: Revit Building 9
20106 downloads
3D Grab Bar w/ Vertical
Product Version: Revit Building 9.1
1767 downloads
84"- 36" Commercial Bathroom Mirror
A Mirror that is used for smaller coimmercial bathrooms
1 Stars from 6 Votes
17012 downloads
ADA Corner Grab Rail for Toilet
Stainless Steel Grab Rail
Product Version: Unknown
15943 downloads
ADA Grab Bar
ADA Grab Bar
ADA Grab Bar
3.5 Stars from 4 Votes
26884 downloads
ADA Grab Bar Shower (Parametric)
Wall-Hosted family.  Curved grab bar for ADA shoower.  Can be mirrored into position if needed.  Fully adjustable w/ pull arrows.
5 Stars from 3 Votes
6692 downloads
ADA Handrails
ADA Handrails
ADA Handrails
14501 downloads
ADA Shower Seat
ADA Shower Seat
Based on ASI 8205.  Seat is not parametric.  Built to nest in a stall shower of a given size.  Width and depth dimensions correspond to shower stall width and depth so the seat positions correctly in the corner.
4.5 Stars from 4 Votes
28103 downloads
ADA toilet grab bars
Includes horizontal side bar, vertical side bar, and back grab bar (behind the toilet). Fully adjustable lengths and mounting heights.
2 Stars from 3 Votes
21829 downloads
Air Hand Dryer
Air Hand Dryer
Air Hand Dryer
1 Stars from 1 Votes
12850 downloads
au.Towell rail - Dbl bracket.rfa
3 Stars from 1 Votes
4824 downloads
automatic air hand dryer - generic
4 Stars from 3 Votes
5105 downloads
Automatic Air Hand Dryer - New and Improved!
Air hand dryer 506 - now a wall-hosted model.  Added symbolic lines so the dryer displays properly in floor plan views.
3 Stars from 2 Votes
25572 downloads
Baby Changing Station
3.5 Stars from 6 Votes
11804 downloads
Bathroom Medicine Cabinet - Simple/Parametric/Editable
4801 downloads
Bathroom mirror
Bathroom mirror
A Bathroom mirror that is also a medicine cabeinet.  Has an excellent rendering appearance and has adjustable lengths
3 Stars from 9 Votes
83653 downloads
Bathroom Vending Dispenser
3935 downloads
wall mounted
4681 downloads
4495 downloads
Bobrick B-2116 Clothes Hook
4478 downloads
Bobrick B-3471
Sanitary napkin and toilet paper dispenser two sided thru wall with partition thikness parameter
1903 downloads
BOBRICK B-43944 SEMI-RECESSED TOWEL DISPENSER & WASTE RECEPTACLE
BOBRICK B-43944 SEMI-RECESSED TOWEL DISPENSER & WASTE RECEPTACLE WITH CORRECT PROPORTIONS & MASK REGION TO COVER WALL PATTERNS IN SPACE BETWEEN UPPER AND LOWER SECTIONS.
4 Stars from 1 Votes
2953 downloads
Bobrick B-68137 Two-wall wheelchair compartment grab bar
This is a Bobrick model #B-68137 two-wall wheelchair compartment grab bar.  It was derived from the Bobrick specificaion sheet (URL noted in Family) and is wall based.
4722 downloads
Bobrick B505 Pass-thru
Pass-thru based on Bobrick B505 specifications. Family set up to allow for right, left and opposite door swings, and should accomodate veriying wall thicknesses. Enjoy
4087 downloads
Bobrick Grab Bar B6137
BOBRICK Grab Bar # B8137
7998 downloads
Bobrick Paper Towel Dispenser - B-3944
this family is not extremely detailed but is perfect for plan and elevation views. It represents the exact dimensions of the Bobrick B-3944 paper towel dispenser.
7286 downloads
Bobrick Soap Dispenser - B-40
this family is not extremely detailed but is perfect for plan and elevation views. It represents the exact dimensions of the Bobrick B-40 soap dispenser.
5560 downloads
Bobrick Toilet Paper Dispenser B-2888
this family is not extremely detailed but is perfect for plan and elevation views. It represents the exact dimensions of the Bobrick B-2888 toilet paper dispenser.
16934 downloads
Corner Bathtub (AEssel Niagara) 16x16
Parametric material.
Model made after corner bathtub "Niagara" from "AEssel"
1610x1610 mm.
It was created in Revit 2013, later was renewed to 2015 version.
3.5 Stars from 3 Votes
21449 downloads
Corner bathtube Niagara AEssel 14x14
1400x1400 mm.
4.5 Stars from 3 Votes
8308 downloads
Page generation time: 0.6326
