63 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 1 |
Andersen Casement and Awning Windows
Andersen windows, basic sweeps are based on standard Andersen detail for 200 series, which generally matches 400 series. All units use same shared nested families, so take care when creating schedules. Rough openings are set to match Andersen 2008 catalog, this may result in some minor discrepencies for actual Unit dimensions. Generally their catalog allows for an extra 1/2" for the rough opening. I provided type catalogs for the casements, got lazy on the awnings. A triple awning can be created by copying the triple casement and reloading the awning nested family (save out of another family). I think I fixed the issue with how the windows are located, they should all have a "Finish Depth" parameter.
Three grille options are included, none, Prarie A and Fractional. New grilles are easy, they are a nested family (not shared) that are placed in the nested window unit(s). You'll see a type parameter in the hosted windows that lets you control which grille option you're using, the type parameter is actually switching the nested window unit, not just the grille.
4.5 Stars from 3 Votes
6097 downloads
Andersen Double Hung Window
Double Hung Window with Adjustable Mullions and Type Catalog
3595 downloads
Classical Window
Classical Window
Product Version: Unknown
165 downloads
Composite Double-Hung
This is a simple composite double-hung window.  The window width and height are adjustable along with the distance between windows. Window width and height adjustments will affect both windows.  Created in Revit 9.1.
1 Stars from 1 Votes
4315 downloads
Frank Lloyd Wright
Frank Lloyd Wright
Funky Design
4095 downloads
Kamals Divisible Frameless Window
180 downloads
Kamals Frameless Double Hung Window
214 downloads
Kamals Top Hung Frameless Glass Window
4 Stars from 1 Votes
303 downloads
Metric Multibay Louvre Window with Adjustable Fixed Glass Panel
Make sure the number of bays is 2 or more.
2 Stars from 1 Votes
12089 downloads
Quarter Round Top
Quarter Round Top
Quarter Round Top
Product Version: Revit Building 5.1
1197 downloads
Quarter Round Top w Trim
Quarter Round Top with Trim
1137 downloads
single hung
single hung
single hung window
8794 downloads
single hung with transom
2287 downloads
single hung with triangle
single hung window with mulled triangle on top
3652 downloads
single hung-2
single hung-2
double mulled single hung
2210 downloads
single hung-2 with transom
double mulled single hung with mulled double transom
1302 downloads
single hung-3
single hung-3
triple mulled single hung window
2959 downloads
single hung-3 with transom
triple single hung mulled with mulled transom abv
1695 downloads
SINGLE HUNG/FIXED/SINGLE HUNG
TRIPLE MULLED WINDOW WITH FIXED WINDOW IN THE CENTER WITH A SINGLE HUNG MULLLED TO EACH SIDE. CAN MAKE ANY COMBO WITH THIAS FAMILY
5496 downloads
slider
slider
sliding window
10049 downloads
UOT - Kamel - Door - Window
UOT - Kamel - Door - Window ... Building and Construction Engineering Department ... University of Technology ... Baghdad, Iraq ...
2818 downloads
Ventana Celosia 2 CUERPOS
Tipo Primavera
3439 downloads
Ventana Celosia 3 CUERPOS
Tipo Primavera
4.5 Stars from 2 Votes
3340 downloads
VENTANA CELOSIA UN CUERPO
Corregido el archivo de descarga (Carlitos).
1451 downloads
Ventana tipo Celosia Verticales Parametrica
Ventana celosia, se puede modificar alto y largo de la misma, las celosias se ajustan automaticamente
4 Stars from 6 Votes
3462 downloads
VENTANA VIDRIO FIJO ESQUINERO
para colocar en esquinas el corte va a 45 grados, va en version 2013 para aquellos que no se han actualizado.
458 downloads
Window
401 downloads
window 1500x1200
window 1500x1200
4 Stars from 2 Votes
Product Version: Revit Building 9.1
2750 downloads
Window Trapezoide
Window Trapezoide
Trapzoidal Window
3 Stars from 2 Votes
9146 downloads
Window Trapezoide 2
Window Trapezoide 2
Window Trapezoide 2
2637 downloads
Page 1 of 1 |
Page generation time: 0.6115
