180-degree swing door |
No rating |
Product Version: Unknown
10179 downloads
5576 downloads
I updated this to allow for different thicknesses of walls. It will create a 4" interior portion of wall and you can have a 4" (or any size larger) exterior portion of the wall. It's loosely based off Weiland exterior sliding pocket doors. This newer version keeps the model objects visible and does not have symbolic/model lines for plan view. |
19248 downloads
AGRV_Door_HiddenEscape_隱藏式逃生門
with parameters for open/close door in 3D view
Metric Hidden Escape door with DIM & Material parameters and dimension Guide
Visit our website AgileRevit.com for more families |
No rating |
434 downloads
Arched Door |
No rating |
11156 downloads
1418 downloads
FIXED
Wall based, double door opening & shelf for a cool room display for a bottle shop or store.
Glass door with stainless steel frame, shelving and handle. 4 shelves that with heights that adjust automatically.
Height, width, offset from floor, shelf depth, handle height and handle size are all PARAMETRIC. |
14280 downloads
Useful as smoke doors, in hospitals, etc. Each leaf swings in direction of egress from each side. |
3556 downloads
Built a fully parametric draw bridge to test out some things. Enjoy |
No rating |
894 downloads
this is a door for a dumpster enclosure |
8442 downloads
This dutch door family is parametric and has an adjustable swing |
11898 downloads
DECORATIVE RESIDENTIAL DOOR WITH SOLDIER COURSE ON 3 SIDES AND KEYSTONE HEAD PIECE |
6629 downloads
Double swing plastic doors for commercial/supermarket stockroom entrance use |
3623 downloads
No rating |
1948 downloads
1200 downloads
Parametric Height, Width and ground clearance. Wall hosted.
2.5" HSS tube & 1.75"x1.75" angle frame with corrigated metal panel inset; not adjustable |
10071 downloads
Aluminum & Glass ICU Door with 1 sliding panel |
9132 downloads
Download: http://bimobject.com/en/hufcor/product/s600_632paired
This is an example of one of the many objects available from this manufacturer on the BIMobject Cloud. Click on the link to find so many more objects which are free for all designers from around the world to use. We also have an amazing app which enables you to access our complete library directly from within your BIM software
Revit app: http://info.bimobject.com/revit-appHufcor operable partitions — also known as Airwalls®, folding walls, flat panels, movable walls, and room dividers — set the standard for quality, durability, acoustic separation, and ease of movement. They are the creative way to add flexibility and functionality to your space. |
1844 downloads
Warehouse Industrial Sliding Door (Adjustable Size) With A Regular Door (Adjustable Size and 45 or 90 Degree Swing)Inserted Inside The Sliding Door |
9908 downloads
Download here:
bimcatalogs.partcommunity.com/3d-cad-models/sso/novospeed-thermo-novospeed-thermo-novoferm?info=novoferm%2Fthermo_asmtab.prj |
No rating |
457 downloads
4562 downloads
Here's a fancy fully parametric arched garage door with details (Also parametric).
I'm still working on making the radius of the arch parametric - I'll upload it if I ever solve all the problems. Also you can't change the number of panels in the door, but they will adjust themselves appropriately as you change the width of the door. |
20008 downloads
upward acting |
Product Version: Revit Building 5.1
20914 downloads
4776 downloads
Ultrascreen Australia screen, as unhosted Component, to be added to inside of doors, for openings up to 2.4m high x 1.7m wide. Smooth version allows screen open at any positioned, reflected in Revit family. |
No rating |
4847 downloads
Ultrascreen Australia screen, as unhosted Component, to be added to inside of doors, for openings up to 2.4m high x 1.7m wide. Standard version only allows screen open or closed, reflected in Revit family. |
No rating |
4633 downloads
Ultrascreen Australia screen, as unhosted Component, to be added to inside of doors, especially larger openings up to 2.4m high x 4.0m wide. |
No rating |
3775 downloads
Ultrasceen Australia screens, as Components, modelled as unhosted, to be added to inside of doors, especially larger openings. |
No rating |
967 downloads
This is my first upload so please be gentel. This is a simple family that allows you to place a shower partition with a curb on 4 sides and glass for the partition, in a room. You can change a lot,
- Curb Heights - independent on all 4 sides
- Curb depth
- Overall Height
- Overall Width (you should be able to use align and lock to make it stretch.
- 2 - Panel or 3- Panel glass partition
- Each partition door has a 2D 45 degree rep for plan view.
- Each partition configuration allows you to put in two override dimensions that I will try to explain.
- Override Panel Width - If you need one of the panels to be say "6" use this to do that. When this is set to 0 it should return to equal equal.
- Override Door Width - If you need the door to be a certain width say 30" enter it here.
This model is not foolproof, although I did do a few basics to keep people out of trouble, like a minimum door height and glass thickness. But if you try to specify a panel override width and a door override width on the 2 panel with the curbs locked to the wall it will probably break. However if you do that on the 3 panel, the 3rd panel will take up the slack.
Please leave your comments for me. Thanks. |
18158 downloads
Fully parametric modern barn-style door. All components are nested families. Default materials as shown in image can be changed in material parameters. |
26878 downloads
