59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 1 |
adjustable downspout
4.5 Stars from 2 Votes
Product Version: Unknown
8535 downloads
Greenhouse Ridge Venting (Single)
Note: Cannot be smaller then 1'
Parametric
By Juul
1299 downloads
Lindab Downpipe System 125/87
Fully parametric Downpipe System object created in Revit Architecture 2016. It consists of a downpipe with a nozzle, bends and different outlet options.
For more downpipe system families and other families from Lindab, visit www.lindab.com/bim
For a complete free of charge LindabRevitLibrary, visit www.lindab.com/lindabrevitlibrary
2 Stars from 2 Votes
3887 downloads
Lindab Downpipe System 190/120
3480 downloads
Lindab Gutter System 125
Fully parametric Gutter System object created in Revit Architecture 2016. It consists of a gutter with optional gutter accessories on the left and right side of the gutter.
For more gutter system families and other families from Lindab, visit www.lindab.com/bim
1145 downloads
Lindab Gutter System 190
3.5 Stars from 9 Votes
5002 downloads
Lindab Gutter Types - 100, 125, 150 and 190
The gutters are available in 4 different sizes and comes in pre-painted steel in 10 different colors, also copper and Magestic.
For size and availability in your country, please visit your local Lindab website.
The Revit file contains gutter types that can be used directly using the built in gutter tool in Revit.
For more families from Lindab, visit www.lindab.com/bim
3 Stars from 3 Votes
4099 downloads
Lindab KFK 125 - Fascia Gutter Bracket - 2D
Fascia gutter bracket created in Revit Architecture 2016.
The family type is Detail Component.
For more rainwater system families from Lindab, visit www.lindab.com/bim
864 downloads
Lindab KFK 125 - Fascia Gutter Bracket - 3D
Fascia gutter bracket created in Revit Architecture 2016. It comes with a type catalogue specifying the available colors.
The family contains information about material quality and links to web tools.
The family type is Face Based Generic Model.
674 downloads
Lindab KFL 125 - Rafter Gutter Bracket - 2D
Rafter gutter bracket created in Revit Architecture 2016.
452 downloads
Lindab KFL 125 - Rafter Gutter Bracket - 3D
Rafter gutter bracket created in Revit Architecture 2016. It comes with a type catalogue specifying the available colors.
321 downloads
Lindab Rainwater System 125/75 Evaluation Version
Fully parametric Rainwater System object created in Revit Architecture 2016. This object is an evaluation version and will be replaced with final versions in September 2016.
Please send feedback to informationgateway@lindab.com and help us improving these objects. We will release the rainwater systems 125/87, 125/100, 150/87 and 150/100 in September 2016.
The family type is Speciality Equipment.
Prefered work order:
1. Component - Place a component
2. Placement - Place on work plane
3. Placement plane - Pick...
4. Specify a new work plane - Pick a plane - OK
5. Select the vertical face of the roof edge
6. Click a start and end point. From Left to Right.
1 Stars from 1 Votes
2512 downloads
Lindab RG 125 - Gutter Stop End - 2D
Gutter stop end created in Revit Architecture 2016.
473 downloads
Lindab RG 125 - Gutter Stop End - 3D
Gutter stop end created in Revit Architecture 2016. It comes with a type catalogue specifying the available colors.
529 downloads
Lindab RSK 125 - Gutter Joint - 3D
Gutter joint created in Revit Architecture 2016. It comes with a type catalogue specifying the available colors.
742 downloads
Lindab SSK 125 - Adjustable Gutter Bracket - 2D
Adjustable gutter bracket created in Revit Architecture 2016.
750 downloads
Lindab SSK 125 - Adjustable Gutter Bracket - 3D
Adjustable gutter bracket created in Revit Architecture 2016. It comes with a type catalogue specifying the available colors.
478 downloads
Parapet wall sweep
Parapet wall sweep
Use wall sweep command. The profile is inteded for wall coping parapet.  Customize to your project.
2646 downloads
Roof Drain - Double
Roof Drain - Double
This a combination of kkerridge roof drain & kshahan roof drain layout.
Parametric
By Juul
3 Stars from 1 Votes
5608 downloads
Scupper with Extension (Canale)
Scupper with extension to give a more decorative appearance than just a hole in the wall for drainage. Parametric size and material. Revit 2017.
1718 downloads
Page 1 of 1 |
Page generation time: 0.4718
