38 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
(3)2x4
(3)2x4
(3)2x4
2.5 Stars from 3 Votes
Product Version: Unknown
7349 downloads
(4)2x4
(4)2x4
(4)2x4
3.5 Stars from 3 Votes
3932 downloads
(5)2x4
(5)2x4
(5)2x4
3999 downloads
06 - Truss - Fink Gable - No Web
Typical Gable-end Truss w/ top-chord offset to allow for rake extensions.  No webs shown (Manufacturer designs that not architects).  Variable chord sizing, slope, bearing length & overhang length.  See also "06 - Truss - Fink- No Web".
1 Stars from 1 Votes
2507 downloads
Typical Truss w/out webbing showing (Manufacturer designs that not architects). Variable slope, chord size, bearing length & overhang length.  See also "06 - Truss - Fink Gable - No Web"
2253 downloads
Adjustable Jack Truss
Jack or Hip Truss with adjustable top chord
5 Stars from 2 Votes
Product Version: Revit Structure 2013
6558 downloads
Deck - 12' 11" x 12' 4"
Satndard deck with railing, stairs, and lattice.  i spent 4 days trying to make this parametric but as the deck got more and more complex it would take way too long to make family types and harder to control.
4.5 Stars from 9 Votes
19888 downloads
Deck - Column - Girders - Concrete Base
This is an awesome little family I must say.  I have made a parametric column/girder/concrete base family where the you can control the number of columns and the column spacing.  The girder cut length will follow as you enter the amount of columns you want.  Can you believe I have totally mastered revit but still can't find a job!!!  Please rate and comment.
5 Stars from 6 Votes
4560 downloads
Dimension Lumber.rfa
2283 downloads
Fink truss
Fink  truss
Wood fink truss, flat bottom chord, fully parametric
13961 downloads
Fink truss
Fink  truss
Wood fink scissor truss, fully parametric
9845 downloads
Fink Double Truss
Fink Double Truss
Standard Double Fink Truss, Flexible for Pitch, Right/Left Overhangs, Member sizes.
8078 downloads
Fink Triple Truss
Fink Triple Truss
Standard Triple Fink Truss, Flexible for Pitch, Right/Left Overhangs, Member sizes.
6081 downloads
Fink Truss
Fink Truss
Standard Fink Truss, Flexible for Pitch, Right/Left Overhangs, Member sizes.
3.5 Stars from 4 Votes
11904 downloads
Jack Truss-Medium Span-Two Cut Plumb
This is the same as the other Jack Truss floating around but this one has a Two Cut Plumb tail.
3.5 Stars from 2 Votes
3714 downloads
King post truss - 6 panel - beam element
This is a 6 panel king post truss.  Variable components are: top and bottom chord width, web width, span, slope, throat depth, and left and right eave overhangs.
Product Version: Revit Structure 2008
6760 downloads
lean to truss
lean to truss
a fully adjustable lean to truss
5 Stars from 7 Votes
12728 downloads
Mono Pitch Truss
Mono Pitch Truss
Mono pitch truss with variable elements:  top chord width, bottom chord width, top chord pitch, eave overhang, web width, end vertical width, throat depth, and elevation of seat
5098 downloads
MULTI- PLY- FRAMING-MEMBER
Excellent Parametric 2d Framing member for your framing plans. 1 Ply, 2 Ply, 3 Ply or 4 Ply all in one. Could be used as a joist, beam or truss in 2d plan view.
2293 downloads
OSHA Wood Guardrail
OSHA Wood Guardrail
This is a floor based Generic Model.
347 downloads
Parametric Window Frame
Can be adjusted for height, rough opening dimensions, and frame depth. Section in between header boards can be adjusted to various materials such as insulation, sheathing, etc.
725 downloads
Posi-Joist PS10
Posi-Joist PS10
Posi-Joist parametric, standard PS10 251x96x46mm
posi-strutt, floor truss, easijoist, posijoist, mittal, wolf system, metal web joists, floor joists, joist, wood joist
parametric, minimum length between walls 692 mm
length between 693 and 1292 mm overlapping web
length above 1292mm array divides length by 600mm
overlap over walls parameters 0mm-width of wall
THIS IS THE FINAL VERSION
666 downloads
Raised Heal Attic Truss
This Is a fully flexible Attic Truss
5636 downloads
Roof Rafters-Cal Frame
This is a set of roof rafters for a gable roof california framed into another roof. It is instance based.
5452 downloads
Roof Rafters-Cal Frame-adjustable spans
This is a set of rafters for a gable roof california framed into another roof with variable bearing heights on each rafter end. Not sure if this is useful in it's present state...
4078 downloads
Roof Rafters-Gable-2 Cut-Plumb-adjustable overhang
This is a set of rafters for a gable roof with symmetrical span but differing overhang lengths. It is for a two-cut plumb roof.
2687 downloads
Roof Rafters-Gable-Two Cut Plumb-adjustable spans
This is a set of roof rafters with adjustable spans on either end. It is for a two-cut plumb roof.
2555 downloads
Roof Rafters-Gable-Two Cut-Plumb
This is a set of rafters for a gable roof with two-cut plumb tails. It is for a symmetrical span.
4.5 Stars from 2 Votes
2303 downloads
Simple Howe Truss - Parametric
Simple 6/12 slope Howe truss.  This family comes fully parametric with respect to bearing width, overhang depth and member sizes.
If you need a different slope this is a good family to start from and modify to fit your project.
Hope you find it helpful!
1729 downloads
Simple Scissor Truss
Simple 6/12 slope scissor truss.  This family comes fully parametric with respect to bearing width, overhang depth and member sizes.
1638 downloads
Page generation time: 0.6212
