Parametric column base with adjustable bearing, gusset plate, and hole dimensions. |
4228 downloads
3562 downloads
Workplane based and modified to meet my companies standard. |
No rating |
Product Version: Revit Structure 2015
1072 downloads
2016 version. Workplane based |
No rating |
Product Version: Unknown
970 downloads
Parametric Spring |
No rating |
2549 downloads
Strctural Steel Column Base plate w/
editable size & bolt spacing |
3579 downloads
Parametric column cap with adjustable bearing, gusset plate, and hole dimensions. |
No rating |
3614 downloads
Revit2017's parametric model of the Doge Table designed by Carlo Scarpa.
http://www.cassina.com/it/collezione/tavoli-e-tavolini/doge
Hope you'll like it
Giuseppe |
1097 downloads
This is a support for ducts. We add a column from the TOS to the bottom of this support. This is created in Revit 2015. There may be some bugs with parameters but it should work for most cases. |
No rating |
1256 downloads
This is a little crude but neat, I think. This fire pit is made of steel. Just need a pipe through the middle for gas and a gas ring. Then fill with stones and viola. |
2197 downloads
garbage, kosz na śmieci |
No rating |
7029 downloads
5847 downloads
A 2D turnbuckle that can change from top view to side view. |
Product Version: Revit Structure 2013
2704 downloads
Created with conceptual mass, the awning width is parametric. |
22229 downloads
Parametric Louver |
11575 downloads
This shear plate is a 3/8x4" plate with 13/16" oblong holes. It is face mounted for columns and has the ability to add or subtract holes. Just go into the properties and change the "needed holes" amount. |
No rating |
Product Version: Revit Structure 2009
1137 downloads
Fully parametric objects to decorate the facade
Made by MJ-objects.dk |
5384 downloads
Parametric Made in RAC 2010 |
No rating |
5253 downloads
Contains three sizes/types for our project. |
No rating |
1232 downloads
2016 version with improvements. There is now always a rung at the reference floor. All parameters are functional. Workplane based. When cut vertically it now how symbolic lines to show the rungs. Also have the ability to dimension from rung centers. |
No rating |
647 downloads
This family is workplane based becuase I got tired of hiding a wall. This means you can put it on a rotated workplane as well. |
No rating |
536 downloads
Modified out of the box ladder to be workplane based and no guardrail. |
No rating |
1361 downloads
2016 Version. Workplane based |
615 downloads
Workplane based and removed the flare from the out of the box version. |
No rating |
386 downloads
2016 Version |
No rating |
656 downloads
The P1000T has slots on one side only. This family can be rotated to any angle so that hangers and supports can be assembled. The length is parametric and the slots will adjust to the chosen length. The dimensions of the Unistrut section match the manufacturer's specifications. |
2983 downloads
No rating |
1592 downloads
