52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 5 | 1 | 2 | 3 | 4 | 5 Next >>
ANP M714-E6-200GLGC_Gooseneck light
Gooseneck light for exterior applications. This model has the shade rotated 90 degrees as it was made for some exterior signage on either side.
No light source or photometrics here, just a simple generic model fixture for representation purposes.
8871 downloads
Arc®
Arc®
Construction: Formed aluminum constructio,Precision anodized reflectors and Completely sealed optic chamber
Lamping/Optics: H.I.D. lamping 50w to 150w, Type II distribution and Cutoff and Full Cutoff classifications.
Design Options: Choice of three architectural mounting arm styles, Choose flat or sag tempered glass lens, Two sizes offer design compatibility from street/parking lot to walkways.
Finish: Multi-step cleaning and sealing process and High quality polyester powder coat finish.
Certifications: NRTL listed, ASTM and PCI for finish, and IDA-Approved "Dark Sky Friendly" (with Flat Lens)
This product features IDA-Approved "Dark Sky Friendly" Full-Cutoff optics.
4 Stars from 9 Votes
19604 downloads
Barcelona Street Lamp Post
Product Version: Unknown
5209 downloads
Barn Outdoor Light
Barn Outdoor Light
Material Parameter
Please Rate
5 Stars from 6 Votes
14769 downloads
Barnlight Gooseneck Light
Exterior light, barn light, gooseneck
13323 downloads
Big Light Pendant Cylinder
This Light is Fully Parametric. It is not hosted. Change parameters, High of ceiling, Cable Length, Pendant Length and Pendant Radius. The part witch attaches to the Ceiling can all so be angled to match the slop of the ceiling. This is done by entering a number with inches over 12" (ex. for a 4/12 slope enter 4")
The light is made by Delray Lighting Inc.
 A 2014 version can be found here.
Hope you like it,
smh
5 Stars from 4 Votes
24356 downloads
This Light is Fully Parametric. It is not hosted.  The part witch attaches to the Ceiling can all so be angled to match the slop of the ceiling. This is done by entering a number with inches over 12" (ex. for a 4/12 slope enter 4")
Because of popular demand I remade this based  off the 2015 verstion that I made a while back.
http://www.delraylighting.com/big_lights.html
 Hope you like it,
smh
4.5 Stars from 2 Votes
8726 downloads
Coach Light
Coach Light
REVIT ARCHITECTURE 2019
Coach Light -
To chnage the Light's materials import the "BracketLight" file
Load into project
Change materials in project of "BracketLight"
8499 downloads
Corral Bollard
Corral Bollard
The Corral bollard offers landscape designers and urban specifiers an exciting bollard design to integrate with existing architectural forms and locales. A classic bollard shape combined with the distinctive “corral” rings and precision workmanship exude an air of confidence and reassurance. A thick-walled column of extruded aluminum fitted with a die-cast, aluminum cover gives the luminaire an overall smooth, crisp form. Available for use with HID sources up to 70Watt, or with triple tube, four-pin, compact fluorescent lamps up to 42 Watt. The Corral bollard is constructed for long-term durability with impact resistant diffuser behind protective die-cast aluminum rings, vandal resistant fasteners, and internal direct bolt anchoring system accessible through a 5" x 6" vandal resistant access door. This fixture is ideal for high traffic locations such as schoolyards, hospitals, stadiums, parks and pedestrian malls. Can be used in conjunction with the Corral Column to give varied illumination possibilities from complementary luminaires.
2.5 Stars from 3 Votes
38171 downloads
Custom Wall-Mount Wall-Wash Light Fixture
Built to emulate the traditional White Tower exterior light fixture.  Parametric Sizes and Materials.  Enjoy!
1 Stars from 1 Votes
8038 downloads
Discera Solar
Discera Solar
Discera Solar offers a sleek architectural form in a solar powered configuration featuring a 39 watt metal halide light source with well defined IDA certified "Dark Sky Friendly" Full Cutoff optics. Engineered to achieve many years of low maintenence, self-contained performance. Sealed gel batteries and "smart controller" held aloft in a PVC easy access compartment.
17149 downloads
ELLIPTIPAR 156 LIGHTING FIXTURE
AVAILABLE IN ANY COLOR!  ADJUSTABLE MOUNTING STEM.
4 Stars from 1 Votes
Product Version: Revit Building 9.1
1888 downloads
Exelia Column
Exelia Column
Construction:  Die-cast aluminum cap and column fitter, extruded column, Natural galvanized steel option available
Lamping/Optics: Up to 150WT6 HID or 60W Cosmopolis lamping.  Choice of Type II or V optics or Full-Cutoff Optics
 Finish: Multi-step process, high quality polyester powder coat finish
 Certifications: NRTL listed, IP 65, ASTM and PCI for finish and IDA-Approved “Dark Sky Friendly”
5 Stars from 5 Votes
6728 downloads
Exterior Coach Light
Dark Bronze coach light.
5 Stars from 11 Votes
37636 downloads
Exterior Light Pole w/ LSI Lamp Heads
Multiple lamp head configurations, heights, and base plate cover option.
3.5 Stars from 6 Votes
10717 downloads
Exterior Pole Light
Exterior Pole Light
12591 downloads
Exterior Pole Light
Exterior Pole Light
9515 downloads
Exterior Sign Light
Exterior Sign Light
2506 downloads
Exterior uplight
Exterior uplight
2888 downloads
Exterior Wall Light
4837 downloads
Exterior wall light
Exterior wall light
9697 downloads
External Concrete Garden Light
12043 downloads
3845 downloads
18748 downloads
3204 downloads
1763 downloads
3762 downloads
2798 downloads
12006 downloads
2.5 Stars from 2 Votes
1934 downloads
Page generation time: 0.6245
