5A 120V Surface Mounted Exit Sign
With Parametric Elevation & Annotation Flipping |
9540 downloads
Parametric Exit Sign. Family is face based so it can be used on a linked ceiling. Available parameters: Color of letters (Red or Green) 1 Sided or Two Sided Arrows to left or right |
Product Version: Revit MEP 2010
4089 downloads
No rating |
Product Version: Unknown
7253 downloads
Electrical Sign |
No rating |
1342 downloads
No rating |
956 downloads
Model Exit sign with direction of travel symbol. This is modified version of someone else's exit sign. |
4437 downloads
http://www.safeglow.com/PhotoluminescentProducts.ExitSign.home.html Professional Interiors Line UL 924 Certification Safe Glow’s™ Professional Interior Exit Signs are UL listed to meet UL 924 standards. The Safe Glow™ Underwriters Laboratories certification number is: 35JS. Professional Interior Exit Signs have 6” letters and are certified to have a viewing distance of 50 feet. Professional Interior Exit signs with 8” letters are available upon request. |
12367 downloads
Double or single-sided ceiling-mount exit sign with adjustable directional arrows both in model and symbol. Model hides in coarse view settings. Symbol shows in plan or RCP views. Symbol hides in fine view setting, or as a parameter. No actual light source. |
15259 downloads
Double or single-sided wall-mount parallel exit sign with adjustable directional arrows both in model and symbol. Model hides in coarse view settings. Symbol shows in plan or RCP views. Symbol hides in fine view setting, or as a parameter. No actual light source. Best placed in elev or 3D views. |
No rating |
14302 downloads
Double or single-sided wall-mount perpendicular exit sign with adjustable directional arrows both in model and symbol. Model hides in coarse view settings. Symbol shows in plan or RCP views. Symbol hides in fine view setting, or as a parameter. No actual light source. Best placed in elev or 3D views. |
No rating |
8714 downloads
Symbol that "lights" up direction of exit |
No rating |
1861 downloads
Exit symbol with multi ways to indicate egress See picture. |
Product Version: Revit Structure 2015
5751 downloads
Modified wonderful Exit sign by smitholino. Changed following: Parametric properties are Instance Base; Except color of sign. Allows user to change individual signs. Made symbol smaller scale. Made directional arrows show with symbol. UPDATE (2010-10-08): Fixed directional arrows matching between symbol & 3d element. |
12673 downloads
No rating |
19157 downloads
