Filtrine Model ES-2-RFC-IW - Remote in-wall recirculating chiller/purifier for serving chilled/purified water to multiple dispensers within 10'-100' via recirculating drinking water loop. (2) Gal. storage tank. Serves a population of (100), (assuming 1 qt./day/person typical usage). |
1452 downloads
erher |
No rating |
321 downloads
This is a fully parametric sink with shared faucet and drains. |
65242 downloads
800 gallon grease trap/oil interceptor |
No rating |
726 downloads
Exterior tap for hose connection |
Product Version: Revit Building 9.1
7865 downloads
Exterior Hose Bibb with adjustable length |
No rating |
3469 downloads
The JUAL Angular bowl outlet consists of a bowl which cumulates the water before it is led to the pipe system of the building. The outlet is delivered with standard pipe diametres 50, 63 and 75 mm.The bowl outlet is made from stainless steel and is delivered with Integrated bitumen or foil membrane.
No rating |
Product Version: Revit Architecture 2019
110 downloads
The design of JUAL angular roof outlet is similar to the vertical roof outlet, but the pipe has a 92° angle immediately after the intlet so water is drained horizontally from the roof. The angular roof outlet can be supplied in all standard diametres from 50 mm to 110 mm with various roof membrane types. |
No rating |
101 downloads
No rating |
203 downloads
No rating |
186 downloads
The vertical bowl outlet consists of a bowl that cumulates the water before it flows down into the pipe system of the building via vertical pipes of standard diametres from ø50 to ø110 mm.Bowl outlets are made from stainless steel and can be delivered with integrated bitumen or foil membrane. |
No rating |
97 downloads
No rating |
102 downloads
JUAL Outlet with a rectangular pipe and 90° angled flange. The outlet can be supplied in many different standard dimensions with cross sections ranging from 77x56 mm to 500x100 mm and lengths from 400 mm to 1000 mm. |
No rating |
57 downloads
No rating |
35 downloads
No rating |
40 downloads
No rating |
30 downloads
No rating |
72 downloads
No rating |
76 downloads
The roof outlet has a rectangular pipe and an inlet with a 45° angle so it matches the fillet / cant strip which is placed in the corner between the roof surface and the parapet. |
No rating |
239 downloads
No rating |
121 downloads
Just your typical Laundry tap |
No rating |
Product Version: Unknown
1628 downloads
