59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 1 |
Hunting Platform
Hunting Platform
Basic wood hunting platform with posts in concrete.
3 Stars from 2 Votes
1302 downloads
Parametric Tower Section
This is a tower section which is 99% parametric.  You can adjust the column thickness, overall width and length.  The beams will adjust with the column dimensions.  This tower section is placed as a "column".
A couple things:
1) The crossmember thickness is not adjustable.  I don't know, i just had a hard time trying to set it up.  If anyone wants to take it and run with it, please do.
2) To make a tall tower you simply stack these columns, if you want to adjust the height of a section you can set its offset from the level its on, then you have to adjust the column height to match.  Simply changing the column height will NOT change the height of the section.
It's my first attempt at a parametric object.
5 Stars from 2 Votes
2630 downloads
Wind Tower
Wind Tower
Product Version: Unknown
1859 downloads
Page 1 of 1 |
Page generation time: 0.1801
