This file is Revit 2016 - it is also NOT parametric
Note : I built this all in Revit Architecture so it is not a family - but more of a editable revit structure that you can put doors and windows and everything you would like into it - see image for further clarification
I couldnt find any shipping containers that would allow you to essentially create a shipping container home so i thought i would make one that anyone can make easy changes too.
To edit the wall material - simply select and edit in the properties browser
To place a window or door - i have already included an insulated wall with gyp that will Host the window or door, so all one has to do, is edit the profiles of the walls to reveal your window or door.
Keep on Imagining!
Don
14717 downloads
Mostly Parametric and Materials
Base and Support arm on /off
Made for a project Hope it works for you
just trying to give back !
Revit 2017 |
No rating |
2944 downloads
Companoin Piece to the Bracing Strut Arm. |
No rating |
2341 downloads
Glazed canopy on steel supports |
Product Version: Unknown
15872 downloads
Adjustable Cantilever Storage Rack, for flat lumber, pipes etc. |
6119 downloads
14" dia decorative column ( generic model)
parameters: materials and height of column
rate and comment for improvement |
29042 downloads
Fully parametric step ladder for situations where you want a step ladder instead of vertical rung ladder |
No rating |
11588 downloads
Wood frame stair with 100mm support beam |
1589 downloads
Parametric parking kiosk by Canada Kiosk (an NRB Company)
More information at http://www.ckckiosk.com/
Modelled in Revit 2012, rendered by Project Neon |
20838 downloads
Precast concrete building with parametric size and finishes. View the link below to find a manufacturer near you.
http://www.precastbuildings.com/ |
4301 downloads
3799 downloads
This is a shade structure with a kitchen on a lake front property. |
27590 downloads
Fiberglass Specialties Steeple SB-28 |
No rating |
1231 downloads
