I created this for use in a stage rigging project so I thought I'd give back to the comunity as this was the first place I looked for one. Family contains Instance Parameters for open & close. |
No rating |
701 downloads
Product Version: Unknown
18218 downloads
40 by 60 ampitheater. Comes set for your standard production. |
618 downloads
Download: http://focuslighting.bimobject.com/5703646100749
This is an example of one of the many objects available from this manufacturer on the BIMobject Cloud. Click on the link to find so many more objects which are free for all designers from around the world to use. We also have an amazing app which enables you to access our complete library directly from within your BIM software
Revit app: http://info.bimobject.com/revit-app
As style and simplicity are the two key elements in the design of this projector, it perfectly matches your meeting room's decor. |
3293 downloads
4455 downloads
Ceiling based projector with variable hang. |
Product Version: Revit Building 9.1
56097 downloads
3001 downloads
Flat Screen Television. Can be mounted on wall.80" |
92813 downloads
Generic Digital Projector |
Product Version: Revit Building 5.1
4093 downloads
A microphone with stand. Every piece has a parameter to control the material. I even added a cord. Please rate. |
21720 downloads
MrGGs metric cinema seat W56_D85_H25
Just place seats on a sloping floor and they will adjust to the slope! |
No rating |
9401 downloads
Overhead Projector |
No rating |
2228 downloads
No rating |
13171 downloads
This is a replica of the new Sony Bravia 60 inch LED LCD 3-D t.v. I havent had any problems with the rendering of the t.v. itself. If you have a problem feel free to leave a comment with your concern and as always, Enjoy!!! I am also planning on designing a custom enclousre for this so it can be a complete entertainment center. If you would like me to make it any certain way, then please comment. Thanks! |
14105 downloads
2009 rev not perametric, you can change materials. dont download the big file, just the small. made mistake |
12310 downloads
This is a straight stage curtain, opened to both sides. The height of the curtain, support rod, and wall opening are all adjustable. Depending on your particular conditions, it may require expanding the size of the curtains on either side. This will require a copy and paste of curtain (the curtain is in two pieces on each side already). Then use the join tool to join as many pieces as you need. Join the two sides separately to retain functionality. Do not group pieces - you will lose functionality. |
28918 downloads
Surround sound Receiver |
No rating |
4136 downloads
