74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 1 |
30ft glass elevator
30ft glass elevator
4.5 Stars from 5 Votes
20413 downloads
40ft tall glass elevator
3 Stars from 1 Votes
12935 downloads
AGRV_GENM-SPCQ_CargoElevatorS_貨用電梯S
StandAlone CargoElevator S (2Door)
Metric CargoElevator S (2Door) with DIM & Material parameters and dimension Guide
Visit our website AgileRevit.com for more families
2871 downloads
AGRV_GENM-SPCQ_ElevatorDoorA_電梯門A
Wall based ElevatorDoorA
Metric ElevatorDoorA with DIM & Material parameters and dimension Guide
3207 downloads
AGRV_GENM-SPCQ_ElevatorDoorB_電梯門B
Wall based ElevatorDoorB
Metric ElevatorDoorB with DIM & Material parameters and dimension Guide
12 downloads
5 Stars from 3 Votes
1190 downloads
AGRV_GENM-SPCQ_PassengerElevatorA-2Way_客用電梯A-雙向
StandAlone PassengerElevatorA  (Side Counterweight)(2Way)
Metric PassengerElevatorA with DIM & Material parameters and dimension Guide
2987 downloads
AGRV_GENM-SPCQ_PassengerElevatorA_客用電梯curse
2086 downloads
Circular Glass Elevator
Hydralic Glass Elevator. Mechanical Room Basement. Elevator is at base level. Open for family/component editing. Use of another creators lighting (see stair light). Currently set for 5 levels each 13'-4" and basement 6'-0".
4.5 Stars from 11 Votes
50698 downloads
Edited wall-based lift
4 Stars from 10 Votes
40543 downloads
Electric Elevator
Electric Elevator
Electric Elevator
3.5 Stars from 24 Votes
Product Version: Revit Building 5.1
168575 downloads
Elevator
Elevator
Passenger 2000 to 4000 and Service 4000 to 5000 elevators all in one family. This is a parametric elevator that can have up to 10 stops. There are many paramaters that you can control like amount of stops, distance between stops, frame size, etc.
4.5 Stars from 39 Votes
97058 downloads
Elevator - Center
Elevator - Center
door opens from center
3.5 Stars from 5 Votes
46387 downloads
Elevator - Side
Elevator - Side
door opens from side
15650 downloads
Elevator 20 floor - Elevador 20 pisos
KONE MonoSpace® 700 20 floor KONE elevator
KONE MonoSpace® 700 Elevador de 20 pisos
2885 downloads
Elevator Control Panel 2D
Detail Item of Elevator buttons. It is 2D figured a 3D one was over kill. In the instance panel there is 2 parameters X/Y Array for the count of buttons.
This is a really simple family but hope it helps
smh
1203 downloads
Elevator updated
Elevator updated
Update to my previuos post
4 Stars from 15 Votes
Product Version: Revit Building 9.1
113638 downloads
Freight Elevator
Freight Elevator
Freight Elevator
4.5 Stars from 6 Votes
38140 downloads
Handicapped Lift for Enclosure
This is a handicapped lift based on Garaventa Genesis system. Intended to be placed in an enclosure as specified on www.garaventa.ca
Product Version: Unknown
5956 downloads
Handicapped Lift for Shaftway
This is a handicapped lift based on Garaventa Genesis system. Intended to be placed in a shaftway as specified on www.garaventa.ca
2.5 Stars from 2 Votes
6278 downloads
Otis Elevator - Single Gen2 3500lb Capacity
model & detail
3 Stars from 2 Votes
9497 downloads
Panoramic Elevator
Panoramic Elevator
Panoramic version of the excellent elevator previously uploaded by mphillips68.
4 Stars from 6 Votes
43557 downloads
Panoramic Elevator
Panoramic Elevator
14084 downloads
Residential Elevator- 14 SQFT
950# RH RAIL, IN-LINE OPENING, ACCORDION GATE, 14 SQFT- The Reserve Series
4.5 Stars from 2 Votes
7097 downloads
ROOF LADDER
Parametric family with constraints to Width, Height, Number of runs, top and Bottom runs...
1898 downloads
Stair Elevator- Garaventa Stair Lift Xpress
2.5 Stars from 6 Votes
10152 downloads
star of life
star of life
star of life required to be shown on stretcher elevators
971 downloads
Page 1 of 1 |
Page generation time: 0.7178
