60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 14 | 1 | 2 | 3 | 4 | 5 Next >>
1 Drawer Base Cabinet
Microwave base
5974 downloads
2 Drawer Base Cabinet
6460 downloads
2-Door Cabinet (editable)
A generic wood cabinet with the handles toward the bottom that you can specify to meet you need. You can move the handles and change the material if needed in the family view.
4 Stars from 12 Votes
Product Version: Unknown
29110 downloads
36'' Lazy Susan Base Corner Cabinet with ONE rotating shelf
1 connected swing-out door with ONE rotating circular shelf
Image is from http://trendkitchencabinets.com/wp-content/uploads/2012/11/Menards-Kitchen-Cabinets-Unfinished-1.jpg
4 Stars from 5 Votes
20157 downloads
36'' Lazy Susan Corner Base cabinet with TWO rotating shelves
Lazy Susan with 1 connected swing out door and TWO rotating shelves
5 Stars from 4 Votes
16003 downloads
6ft by 3ft Mirror w/ wood trim
wall based 6ft wide by 3ft high mirror designed for public bathrooms. Default 4ft above floor.
3 Stars from 5 Votes
37975 downloads
72" LCD TV WALL MOUNTED
yeah just a big tv. wall mounted 3 ft above floor.
3.5 Stars from 11 Votes
51325 downloads
ADBK_FURN_WardrobeI_I型衣櫥
Metric I shape Wardrobe with dimension and dimension Guide
#hangers Can be seem in floor plan
1611 downloads
Adjustable Double Vanity
Adjustable Double vanity bench top and tops. Not fully modeled. Better be used only in plan and elevation views.
5 Stars from 3 Votes
4405 downloads
AGRV_FURN_WardrobeI_I型衣櫥(instance)
instance width and depth
1350 downloads
AGRV_FURN_WardrobeL_L型衣櫥
Metric L shape Wardrobe with dimension and dimension Guide
1663 downloads
AGRV_FURN_WardrobeL_L型衣櫥(instance)
( instance width and depth)
1976 downloads
AGRV_FURN_WardrobeU_U型衣櫥
Metric U shape Wardrobe with dimension and dimension Guide
1183 downloads
AGRV_FURN_WardrobeU_U型衣櫥(instance)
1855 downloads
Angled Corner Cupboard
Angled corner cupboard. (Part of the default revit domestic kitchen set)
3680 downloads
ASIA MODERN
1377 downloads
ASIA MODERN
ASIA MODERN
3.5 Stars from 3 Votes
18241 downloads
AWI 100 - Base Cabinet - Open
Base Cabinet - Open
*** IMPORTANT: The shared parameters file must be pointed to inside Revit.  All casework families built by myself can point to the same shared parameter file. ***
  • Do not adjust parameters under "Other" category.
  • Please save the shared parameters file in the same directory as the cabinet family.
Any comments would be appreciated.
4243 downloads
AWI 101 - Base Cabinet - 1 Door
7183 downloads
AWI 102 - Base Cabinet - 2 Door
4 Stars from 1 Votes
12361 downloads
AWI 141 - Base Cabinet - Sink, 1 door
Base Cabinet - Sink, 1 Door
4807 downloads
AWI 142 - Base Cabinet - Sink, 2 door
7949 downloads
AWI 150 - Base Cabinet - False front, open
2376 downloads
AWI 151 - Base Cabinet - False front, 1 Door
2745 downloads
AWI 152 - Base Cabinet - False front, 2 Door
3872 downloads
AWI 210 - Base Cabinet - 1 Drawer, Open
Base Cabinet - 1 Drawer above open
3269 downloads
AWI 211 - Base Cabinet - 1 Drawer, 1 Door
Base Cabinet - 1 Drawer above 1 Door
1 Stars from 1 Votes
5206 downloads
AWI 212 - Base Cabinet - 1 Drawer, 2 Door
Base Cabinet - 1 Drawer above 2 Door
5658 downloads
AWI 230 - Base Cabinet - 3 Drawer
8108 downloads
AWI 254 - Base Cabinet - 4 Drawer
7505 downloads
Page generation time: 0.6620
