116 Users Online (116 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 1 |
adjustable louvre (louver) / venetian blind
Variable in width, height, slat dimensions, angle, material etc. - frame / no frame - work plane based.
5 Stars from 3 Votes
12553 downloads
Awning
Awning
Fully parametric decorative awning.  You might run into some problems if you try to make it too small, but it works at most standard sizes.
I cannot upload it as an earlier version of Revit.  Sorry.
5 Stars from 2 Votes
16953 downloads
Concealed Roller Shade
Adjustable length roller shade w/ on/off shade and adjustable shade length.
11"x7" box w/ blackout shade AND transparent shade
5265 downloads
Curtain
Curtain
This curtain is completely parametric. You can control the length, width, and depth. In addition to that, you can also control the number of curtain "panels". Just select a number greater than 2 for the panels and you can make the curtain panel as wide as you need it.
24987 downloads
Curtain
Curtain
Parametric Curtain
3 Stars from 1 Votes
7083 downloads
Curtains
Curtains
Fully Parametric curtains with type settings for height, width, drop, materials.
5 Stars from 10 Votes
48773 downloads
Curtains - Parametric
An unnecessarily parametric curtain family. This was more of an exercise as opposed to something practical.
The curtains can be parametrically opened and closed through a slider in plan view. In order to do this it took calculous, trigonometry, and numerical methods to pull off. It is a little computationally heavy on the model.
Parameters include:
Materials, Curtain length/width/thickness, rod length/diameter, wall offset, grommet diameter/spacing, left/right/double curtains.
5 Stars from 6 Votes
Product Version: Unknown
18894 downloads
Parameters include:
3.5 Stars from 3 Votes
8259 downloads
Curtains and Valance
These curtains are about 14' tall and 8' wide. Should be simple to change the material. If you have issues, comment below and I'll see what I can do to help. First upload, so I hope it works!
13714 downloads
CURTAIN_70" high
CURTAIN_70" high
I added a material for fabric which you can change. But this is non-parametric curtain.
4.5 Stars from 12 Votes
39190 downloads
decor 150 vertical blind
3 Stars from 2 Votes
2139 downloads
decor 160 mono vertical blind
1435 downloads
one flower window
one flower window
348 downloads
Parametric Curtain
Parametric Curtain
First Upload!
A Parametric Curtain - Ceiling-Type Object
You can change the curtain width, height, its distance from the ceiling, the rod length and location. Curtain and Rod materials are parametric. It'll look funny if you make it too small or too big - it's ideal at around 5'-0" in width.
Tags: Curtain, Blind, Shade, Drape, Window Treatment
3.5 Stars from 19 Votes
125455 downloads
Parametric Window Blinds
These blinds are fully parametric. You can adjust the height and width as well as the angle and depth of the blinds.
All parameters are instance based.
Regenerates much quicker than other blinds families.
5 Stars from 4 Votes
12120 downloads
roller blind for indoor and outdoor
parametric object adjustable in height and width with the choice of materials
oggetto  parametrico regolabile in altezza e larghezza con scelta dei materiali
objeto paramétrico ajustable en altura y anchura con la elección de los materiales
8573 downloads
Roman louvers
Roman louvers
Parametric materials and width.
2795 downloads
Shutters
Shutters
Fully parametric. You select the blade angle and size.
1 Stars from 1 Votes
5225 downloads
Spindle Wall Pc.
Spindle Wall Pc.
Spindle piece to make into a curtain panel
165 downloads
Sunshading
Sunshading
This sading system was made as part of my BIM module is fully parametric, blades number, depth, length and angle are adjustable.
hope you enjoy it
1250 downloads
Vertical Blinds
Vertical Blinds
Vertical stripes blind. I think every possible parameter has been included, even a logic formula to avoid the final width of the blinds to go beyond the length of the top rail. I hope it´s good for someone, thank you all for all your generous effort, it´s just a small feedback. Please study the family types parameters to fully understand the way it works.
4.5 Stars from 7 Votes
29122 downloads
Window Blind
Window Blind
Fully Parametric for overall width and height. All facets of the blind can also be adjusted from transom width and depth to the blades width and thickness. Can be displayed as open, partially open or closed.
4 Stars from 14 Votes
14730 downloads
Window Blinds, Lamellae
Parametric set of window blinds / curtains / lamellae. The lamellae can be set to be set to span the entire window or be set to the side, it can be rotated between two limits of degrees ensuring you cannot overclose the lamellae. You can set the width and the height of the blinds to your custom size.
Hope you like it.
9918 downloads
Page 1 of 1 |
Page generation time: 10.9534
