Generic 1.5m long 800mm high 300mm wide road traffic barrier |
No rating |
1000 downloads
14,000lb. Four-Post Vehicle Lift |
Product Version: Revit Building 9.1
11925 downloads
Old Chevy Caprice with 30" Rims, wowza!!!
Enjoy!!! |
4432 downloads
7 x 16 foot enclosed trailer with side door |
Product Version: Unknown
3124 downloads
Portable aircraft tripod assembly used for supporting airplanes while being serviced. Usually three assemblies are used per plane. Length of piston is adjustable to suit the various support heights. |
No rating |
1613 downloads
bicycle rack with seating |
5550 downloads
Not Parametric but all elements are editable to put your materials... |
8009 downloads
This is a basic parklift patterned from Wohr parklift 440. Feel free to edit for I am not that sure with the 3d components; but this is a good framework, though. Hope to update soon. |
No rating |
1622 downloads
No rating |
2426 downloads
Mountainbike. This file contains a 2D for the planviews and a 3D |
30782 downloads
Metal framed Bike Shelter with perspex cover & Sheffield Stands |
4327 downloads
Standard Steel Frames with Glass/Perspex Roof & sides |
2435 downloads
788 downloads
Camper Van
Modded off of an existing van on this site. Very basic but it did what I needed.
Modify further if you wish. Materials are basic also.
RevitLT 2018 |
4632 downloads
11624 downloads
This is a basic car chassis straightening bench / car frame repair rack.
It is not parametric. |
Product Version: Revit Structure 2019
1526 downloads
Car Lift |
25509 downloads
This a 8x4.5m car paint booth with internal lights, not parametric, but should be pretty easy to edit to fit your model. (The lights might be a little too bright, idk)
The full model is 9x4.5m |
Product Version: Revit Architecture 2019
1488 downloads
Coats Tire Changer (unsure of model #, this was modeled from an existing to remain piece of equipment in a project) |
No rating |
1786 downloads
Crane with a lot of parameters |
No rating |
732 downloads
NOT Wall Based, can be placed anywhere and customized. Rubber Array is also parametric and will fill in to customized size. |
4269 downloads
Floor mounted dock leveler plate with bumpers |
7243 downloads
Here is a parametric dock leveler based on this model: http://www.beacontechnology.com/docklevelers/edgeofdockleveler/ It is not wall based, so it can be put anywhere. |
4668 downloads
Floor Based and parametric to customize size. |
No rating |
1586 downloads
E Scooter rack - single or double sided. Turn Scooter off if not required. Enjoy. |
No rating |
874 downloads
Engine Crane - Someone requested this so I hope it helps.
FILE TYPE: Revit 2012 64 bit |
5909 downloads
14927 downloads
Modelo para estacionamiento exclusivo de discapacitados paramétrico con una altura libre de 1.75m.
Disfrutenlo. Saludos |
4672 downloads
Front/Back selected by parameter (the only way I know) |
11824 downloads
Thanks, Cheesemonkey8402! This is a modification on the std horse trailer. I used it for a tumbleweed house. |
No rating |
7357 downloads
