83 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
Automated external defibrillator
Semi Recessed AED - Wall Hosted
4632 downloads
BARRIER CABLE SYSTEM
These family was made for showing barrier cables around a parking deck.
1489 downloads
Bracket Mounted Fire Extinquisher
This resolves the scale issue with other bracket mounted extinguishers.  Family is not really parametic, but based roughly on the largest cylinder out there @ 8" diameter x 30" tall.  Mounting height is parametric, measure from highest point on handle.
3.5 Stars from 3 Votes
17748 downloads
Code Blue Emergency Phone
1453 downloads
Easy Glass Max Q-railing
EasyGlass Slim Easy Glass Glasgeländer Balustrade Full glass balustrade balcony Balkon Ganzglasgeländer Balkongeländer Ganzglas  Glass Glas Terrasse ESG Galerie VSG Treppen Stairs Bending Gebogen Safety Sicherheit Absturzsicherung Balkonverglasung Verbundsicherheitsglas Brüstungsgeländer Slim Side Slim Top Topmount Fasciamount Bodenprofile Linienförmige Verglasung Trav DIN18008 Klemmprofile Systemgeländer Bodenmontage Traversengeländer Nur-Glas  Railingsystem Architectural balustrade balconies base channel base shoe BS6180 channel system fall protection stairway q-railing stair stairs Geländerbasis Safty Wedge  Full Glass balcony
1015 downloads
Easy Glass Pro Q-railing
938 downloads
4 Stars from 1 Votes
2509 downloads
Easy Glass Slim Q-railing
1308 downloads
Eye Wash and Safety Shower Station
A wall-embedded eye wash station with a safety shower mounted through the ceiling. The model is made to adjust in elevation for the eye wash station, shower head height, and ceiling height. The only caviat to this exact model is that the "Elevation" instance property needs to match the "Box Elevation" type property.
1724 downloads
FHR_no cabinet
FHR_no cabinet
FHR_no cabinet
Product Version: Unknown
1871 downloads
FIRE EXTINGUISHER
1 Stars from 1 Votes
Product Version: Revit Building 8
2092 downloads
Fire Extinguisher Cabinet - Recessed
2.5 Stars from 4 Votes
8846 downloads
fire extinguisher cabinet - recessed
1681 downloads
fire extinguisher cabinet - surface mounted
10455 downloads
Glass Railing
Glass Railing
Glass railing in aluminum extrusion with round wood handrail
3.5 Stars from 16 Votes
89076 downloads
HANDRAIL
HANDRAIL
Handrail commonly used in Hospitals.
Parametric length. adjust height with elevation
4031 downloads
Knox Box Key Cabinet
Model no. 3264. This is arecessed Knox box with a hinged door. Color: Dark Bronze. There are material parameters loaded.
3 Stars from 2 Votes
6290 downloads
Metal Detector
Metal Detector
Metal Detector
Product Version: Revit MEP 2013
4993 downloads
Pool Safety Ladder - Facebased
Revit version 2019 Parametric pool Safety ladder Facebased
All relevant size are parametric
such as
  1. Width
  2. Pool Depth
  3. Pool base offset for Lowest Step
  4. Step Width
  5. Rail height
  6. Rail Extension
  7. Step Offset from Pool Wall
19490 downloads
Portable Platform
Portable Platform
Here is a 6'-0 Portable Platform or Movable Stair. There are some adjustable parameters to the height of the Platform but the number of treads will not increase, just will eq. out
1687 downloads
PPE Glove Dryer
PPE Glove Dryer
Floor Based Family:
Williams G18E 18 pair Glove Dryer
560 downloads
recessed fire extinguisher cabinet - simple
a bare-bones, wall hosted, recessed fire extinguisher cabinet, for when you don't need a lot of geometry.
4 Stars from 2 Votes
6200 downloads
Safety Gate
Safety Gate
Safety Gate with adjustable width.
4384 downloads
safety ladder 1
metric safety ladder with cage
Product Version: Revit Structure 2010
937 downloads
SAFETY MIRROR 180 DEGREE
180 degree mirror commonly used in Hospitals.
renders well. Not wall or ceiling based.
1756 downloads
SAFETY MIRROR 360 DEGREE
360 degree mirror commonly used in Hospitals.
2044 downloads
SAFETY MIRROR 90 DEGREE
90 degree mirror commonly used in Hospitals.
1550 downloads
Safety Shower & Eye Wash
5 Stars from 2 Votes
9742 downloads
Speed Limit Sign 20
Speed Limit Sign 20
Speed limit sign
2771 downloads
Speed Limit Sign 30
Speed Limit Sign 30
Speed limit sign
1844 downloads
Page generation time: 1.0143
