10 - Toilet Accessory - Sanitary Napkin Disposal |
Product Version: Revit Building 9
20106 downloads
2x2 square table with parametric height |
1470 downloads
No rating |
Product Version: Revit Building 9.1
1767 downloads
These files are based on 3Form Panels and 3Form Suspend Solutions Hardware. These files are meant to be used together and placed into the Project Environment. The Panel can be customized in width and height (Note that 3Form panels are typically 4'-0" wide by 8'-0" high maximum) and is placed by the centerline in height to coordinate with the suspension system parameters. The hardware suspension system has adjustments for overall height and the panel centerline height to move the clips up and down. The clips can be switched from center clips to end clips and the bottom attachment can be changed from floor mounted to wall mounted as well. NOTE: THIS DOWNLOAD ONLY DOWNLOADS THE PANEL. THE SUSPENSION SYSTEM IS A SEPARATE DOWNLOAD. |
7729 downloads
These files are based on 3Form Panels and 3Form Suspend Solutions Hardware. These files are meant to be used together and placed into the Project Environment. The Panel can be customized in width and height (Note that 3Form panels are typically 4'-0" wide by 8'-0" high maximum) and is placed by the centerline in height to coordinate with the suspension system parameters. The hardware suspension system has adjustments for overall height and the panel centerline height to move the clips up and down. The clips can be switched from center clips to end clips and the bottom attachment can be changed from floor mounted to wall mounted as well. NOTE: THIS DOWNLOAD ONLY DOWNLOADS THE SUSPENSION SYSTEM. THE PANEL IS LOCATED IN A SEPARATE DOWNLOAD. |
No rating |
3993 downloads
A Mirror that is used for smaller coimmercial bathrooms |
17012 downloads
No rating |
3725 downloads
Stainless Steel Grab Rail |
No rating |
Product Version: Unknown
15943 downloads
ADA Grab Bar |
26884 downloads
Wall-Hosted family. Curved grab bar for ADA shoower. Can be mirrored into position if needed. Fully adjustable w/ pull arrows. |
6692 downloads
ADA Handrails |
14501 downloads
Based on ASI 8205. Seat is not parametric. Built to nest in a stall shower of a given size. Width and depth dimensions correspond to shower stall width and depth so the seat positions correctly in the corner. |
28103 downloads
Includes horizontal side bar, vertical side bar, and back grab bar (behind the toilet). Fully adjustable lengths and mounting heights. |
21829 downloads
Air Hand Dryer |
12850 downloads
This replaces the original 3701 file, which had a problem with the frame depth in Section |
No rating |
4842 downloads
au.Towell rail - Dbl bracket.rfa |
4824 downloads
automatic air hand dryer - generic |
5105 downloads
Air hand dryer 506 - now a wall-hosted model. Added symbolic lines so the dryer displays properly in floor plan views. |
25572 downloads
Baby Changing Station |
11804 downloads
No rating |
4800 downloads
A Bathroom mirror that is also a medicine cabeinet. Has an excellent rendering appearance and has adjustable lengths |
83652 downloads
Bathroom Vending Dispenser |
No rating |
3935 downloads
wall mounted |
No rating |
4681 downloads
No rating |
4495 downloads
No rating |
4478 downloads
Sanitary napkin and toilet paper dispenser two sided thru wall with partition thikness parameter |
No rating |
1903 downloads
BOBRICK B-43944 SEMI-RECESSED TOWEL DISPENSER & WASTE RECEPTACLE WITH CORRECT PROPORTIONS & MASK REGION TO COVER WALL PATTERNS IN SPACE BETWEEN UPPER AND LOWER SECTIONS. |
2953 downloads
This is a Bobrick model #B-68137 two-wall wheelchair compartment grab bar. It was derived from the Bobrick specificaion sheet (URL noted in Family) and is wall based. |
4722 downloads
Pass-thru based on Bobrick B505 specifications. Family set up to allow for right, left and opposite door swings, and should accomodate veriying wall thicknesses. Enjoy |
4087 downloads
BOBRICK Grab Bar # B8137 |
7998 downloads
