62 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
A BASIC CASKET
A BASIC CASKET
NEEDED A CASKET FOR A PROJECT I WAS DOING.  I DIDN'T SEE ANY ON HERE SO I MADE A VERY BASIC ONE.
999 downloads
ADA Corner Grab Bar
ADA Corner Grab Bar
Fully adjustable ADA grab bar for use in restrooms
2 Stars from 1 Votes
26563 downloads
ADA_Shower_Seat_4472.rfa
1 Stars from 1 Votes
2396 downloads
Adjusting massage chair
This is not perfect. this is my first upload.  I quickly made this ProAduster Chair out of a weight bench.
Hope it helps someone.  Chair should be around 46" x 25"
3.5 Stars from 3 Votes
6695 downloads
Airport security check
A security check found in airports. Does not include a computer.
6722 downloads
Bridge Crane
Bridge Crane
This is a parametric Bridge Crane
4829 downloads
Call of Duty Nuketown Sign
Currently building an exact scale revit model of Nuketown the Call of Duty course. Thought that I would upload the sign that I built just in case any of you want it or need it. Not Parametric,it is a little over 6'3" tall and 9' wide. Let me know what you all think?
Product Version: Unknown
1042 downloads
Cash Register-POS
Cash Register-POS
Point of Sale
2.5 Stars from 3 Votes
41871 downloads
Computer Stand with monitor, key board and mouse
Computer Stand with monitor, key board and mouse - if you need any help with families or Revit Architecture please email me at k.d.madsen@hotmail.com
14527 downloads
DO NOT USE
DO NOT USE
Cant figure out how to delete this family. use the other one uploaded by me instead.
232 downloads
Drinking Glass - Short
5255 downloads
Drinking Glass - Tall
5272 downloads
Facade wall ladder with safety rail
Facade ladder for evacuation, ascending to the roof and chimney.
Installed with a bracket depending on the depth of the roof foot. Handrails shall be installed with a bracing kit on facade ladders and on roofs or other permanently installed access device.
Satisfies the requirements set out in SS 831340
Made in Sweden by CW Lundberg AB
714 downloads
Floor foot Grill - Slab depression grille - Parametric
This is a parametric floor grill.  Includes a slab depression that is parametric.  Used in building entryways to remove dirt, snow or slush from shoes and boots.
2350 downloads
Folding Partition (Accordion Panel)
Generic accordion style partition.
3038 downloads
Full Stack Amplifier
1957 downloads
Guillotine
Guillotine
Have Fun.
2006 downloads
Hair Dryer Holder
Hair Dryer Holder
Wall-mounted hair dryer holder modeled after Moen Voss unit
2193 downloads
Highball Glass
Highball Glass
2435 downloads
Hurricane Glass
Hurricane Glass
3102 downloads
Martini Glass
Martini Glass
5546 downloads
Midmark 604 Exam Table
Midmark Equipment - Table 604
6620 downloads
Potted Plant
Potted Plant
Great as an indoor plant or decks
3.5 Stars from 4 Votes
41727 downloads
Rail roof hatch
Rail roof hatch
Rail (0.5 m height) at the access hatch and around skylights etc. from supports when ascending/descending to the roof and shall prevent people from going onto roof areas that cannot withstand the weight of a person.
They are also approved for the anchoring of personal fall protection according to SS 831333.
546 downloads
RAMPA PARA CALÇADA (ACESIBILIDADE) - REVIT 2015
REVIT 2015
R1
Altura: 0,15 m
Largura: 1 m
Comprimento: 5 m
R2
Altura: 0,15 m
Largura: 1 m
Comprimento: 4 m
R3
Altura: 0,15 m
Largura: 1 m
Comprimento: 3,67 m
R4
Altura: 0,15 m
Largura: 1 m
Comprimento: 14,79 m
R5
Altura: 0,15 m
Largura: 1 m
Comprimento: 6,31 m
R6
Altura: 0,15 m
Largura: 1 m
Comprimento: 6,83 m
2138 downloads
Roof safety single anchor point
The function of the anchor loops and ridge rail is to rofm an anchor point for personal fall protection. The ridge rail is used on pitched roofs; on low-pitched roofs (pitches of less than 6 degrees) with asphalt or artificial material-based sealing surfaces, anchor loops are used.
224 downloads
Roof safety the Ridgerail 1m
372 downloads
Roof steps for metal sheet
Roof steps are a simple way to creat an access route, for example, up to a chimney. They may be used on roofs of up to a 4-meter access height with a pitch of a 45 degrees.
They are installed in a straight line one over the other are finished off with anchoring device for personal fall protection, for example , a rdige rail.
242 downloads
Safety triangle
Safety triangle
Safety triangle
Product Version: Revit MEP 2018
157 downloads
Slide Open type 3/4
Slide Open type 3/4
Pack of Open 3/4 900mm water/dry slide for playground or theme/water park.Consisting 30,45,60 degree slide.
2117 downloads
Page generation time: 2.6604
