65 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
2d sweep profile
2d sweep profile
I'm pretty new on revit families. This is a little profile that you can attach to your wall as reveal to make it look like a corrugated metallic face.
Revit version: 2017
Product Version: Unknown
3835 downloads
Baseboard Molding
Baseboard Molding
Adjustable Baseboard Molding.
10337 downloads
Bloco 8 Furos Paramétrico
Bloco/meio bloco 8 Furos paramétrico
1023 downloads
Board & Batten 1x4 @ 20 oc
model pattern - Board & Batten 1x4 @ 20" oc
2 Stars from 9 Votes
0 downloads
3.5 Stars from 6 Votes
0 downloads
Board and Batten
Board and Batten
Fully Parametric Board and Batten generic model wall based family.
Had to fix a few things that were broken. All good now
3203 downloads
Board Batt
Board Batt
model pattern - Board Batt
4 Stars from 1 Votes
14101 downloads
coner round over
coner round over
rounded corner profile for sweeps around objects you may need to have a rounded over edge
3 Stars from 2 Votes
4602 downloads
Corner Guard
Corner Guard
Parametric Corner Guard.
Image shows the corner guards on each side of the door openings.  Also shown are the elevator call and elevator indicator families avilable aon RC.
3.5 Stars from 4 Votes
9780 downloads
corner guard inverted^
Parametric corner guard with adjustable height. Choose correct wall for corner guard to work
1685 downloads
Dentil
Dentil
Dentil cornice - wall hosted
2559 downloads
наличники
наличники
1859 downloads
наличники
наличники
4281 downloads
наличники
наличники
1295 downloads
наличники
наличники
664 downloads
наличники
наличники
600 downloads
наличники
наличники
771 downloads
Exterior Window Trim Boards
Fully Parametric exterior window trim: 1x4, 1x6 and 1x8 types. Just place on exterior wall and use align tool to fit around window.
2064 downloads
HardiePlank - Design Collection - Custom Beaded Profile Sweep with Lap
This is a wall sweep to simulate HardiePlank - Design Collection - Custom Beaded.  The profile is both inward and outward. The insertion is the bottom inside corner to your face of wall. It slants into the wall face. It is 8" High and designed to overlap 1 1/4" - Just like the real thing. Because of the overlap, use is tricky. You (probably) won't be able to array the sweep. You have to first copy it up 8" - then move the copy down 1 1/4". For some reason, Revit will not allow you to copy it up 6 3/4" - Don't know why. Maybe becase of the triangular inset. Of course, you can place them one at a time but I prefer to do the bottom row of a whole house first, then copy the entire thing upward. Hope you find this one useful. You probably wouldn't want to use this technique for really large projects but for most Residential it works just fine. Enjoy.
4128 downloads
HOLLOWED PANEL
HOLLOWED PANEL
427 downloads
Lattice (Parametric with Parametric material)
Actual Lattice (NOT A PAT FILE) PARAMETRIC, ADJUSTABLE, MODELABLE...  RENDERABLE....
Please take, make better and reupload....
revit version 2018 SORRY!
7863 downloads
Metal cladding sheet for curtain wal
Im pretty new on revit families. This is a curtain wall panel that looks like metallic cladding. It's not parametric and if you want to change dimensions you have to do it in the family. Feel free to download, change, and improve as you want
9018 downloads
Added as sweep profile to your wall it will look like a metallic profilled face.
Revit version: 2017
1135 downloads
Nicho Embutido na Parede
Nicho embutido na parede, mais usado em banheiros.
Parametrizado.
1668 downloads
Parametric Vertical custom facade
Change height, spacing, length etc.
Product Version: Revit Structure 2013
10203 downloads
Profile CImalha
Profile CImalha
Profile para fazer os sweeps da cimalha.
3.5 Stars from 2 Votes
6433 downloads
profiled metal sweep profile
Revit version: 2017
906 downloads
rectangular curtain panel at spider fixtures; Painel cortina com fixador
non parametric, only for change the regular curtain panel you already did, materials can be changed, hope someone like this!!!
não é parametric, apenas para substituição do painel cortina que você já fez, os materiais podem ser modificados, espero que gostem!!!
4 Stars from 11 Votes
25618 downloads
REVEAL-BRICK COURSE
REVEAL-BRICK COURSE
1 TO 6 COURES BRICK REVEAL FOR FOUNDATION WRAPPING
2224 downloads
Slatwall 10' tall
Slatwall 10' tall
a 10' tall slatwall. Height is set, length and materials are parametric. slats are 4" apart.
4 Stars from 2 Votes
4427 downloads
Page generation time: 0.6425
