51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 29 | 1 | 2 | 3 | 4 | 5 Next >>
0850_Window-Single_WIN_WB
This window family has type parameters to drive shim space, frame, mullion, & sash width & depth, glazing unit thickness and materials. Also, wall sheathing location can be set by instance for different wall assemblies, the flange setback will control how far in front of the sheathing the window will project. Lites & transom can be toggled on or off. Also, this family features nested families for picture, casement, awning, gliding, & single hung operation with proper representation in elevation for window, lites, and transoms. This should accommodate a wide variety of window configurations in a single family.
4.5 Stars from 4 Votes
8665 downloads
1200 x 1800 Arched window with Sunray transum
3 Stars from 11 Votes
Product Version: Unknown
37362 downloads
1900's Home Window
1900's Home Window
Parametric Height/Width
5 Stars from 2 Votes
7308 downloads
1X6 window trim
1X6 window trim
1X6 window trim
5201 downloads
2 Double Hung Windows with Center Post
2 Double Hung Windows with Center Post.  Width and Height are adjustable along with materials.
3.5 Stars from 2 Votes
3322 downloads
2 panels glass window (Janela de vidro temperado 2 folhas)
Família originária da criada por Winderson Soares Matos
3.5 Stars from 4 Votes
1349 downloads
2' X 2' Fixed Pane Window
Craftsman touch 2' X 2' fixed pane window
Trim width and color is changeable
Done in Revit 2014
10811 downloads
2Bay Wooden Window Frame
Window frame for 2 Single/2Double side hung window leaves+upper & lower  top hung vent leaves, Security grills my also be used. Vent Ht and Low Lite Ht can be set to zero. All dims are parametric. By Er. L.J.Upadhyay. Varanasi India 919919640999
453 downloads
2x fixed window
2x fixed window
stacked 2 fixed windows. completely parametric. can adjust width  and then height of each
1 Stars from 1 Votes
9924 downloads
3x2 Wood Transom Window
3 Stars from 1 Votes
15585 downloads
4-Pane Sliding Glass Door
Four equal width panes, Aluminum and tempered glass door. Trim width and projectiion,rail and stile width adjustable. Metric.
4.5 Stars from 12 Votes
63749 downloads
4-Pane Sliding Windows w/ Double and Quadruple Awning Transom
Aluminum and tempered glass window showing handles. All dimensions and materials parametrized. Metric.
4.5 Stars from 15 Votes
43255 downloads
4-Pane_Sliding_Windows_w_Double_and_Quadruple_Awning_Transom_4527.rfa
4 Stars from 5 Votes
10568 downloads
40mm Casement window
this is a 40mm casement window modeled off the Vantage profile, all elements are extruded profiles right down to the neoprene seals, this file is quite large but excellent for showing that extra detail in your project.  I think i've managed to iron out all the kinks, and yes this window is parametric.
3.5 Stars from 7 Votes
22391 downloads
40mm Double Casement Window - adjustable pane widths
this is a fixed 40mm double casement window modeled off the Vantage profile, all elements are fully extruded right down to the neoprene seals.  This file is quite large but excellent for adding that extra detail to your peoject.  I think i've managed to iron out all the kinks.  This window is fully parametric.  One awning & one fixed pane - both panes have adjustable widths
19826 downloads
40mm Double Casement Window - even
this is a fixed 40mm double casement window modeled off the Vantage profile, all elements are fully extruded right down to the neoprene seals.  This file is quite large but excellent for adding that extra detail to your peoject.  I think i've managed to iron out all the kinks.  This window is parametric.  One awning & one fixed pane - even
4.5 Stars from 5 Votes
26702 downloads
40mm Double Fixed Window - Even
4 Stars from 12 Votes
61442 downloads
40mm fixed window
40mm fixed window
this is a fixed 40mm window modeled off the Vantage profile, all elements are fully extruded right down to the neoprene seals.  This file is quite large but excellent for adding that extra detail to your peoject.  I think i've managed to iron out all the kinks.  This window is parametric.
4.5 Stars from 2 Votes
31353 downloads
40mm Triple Casement Window - Adjustable
this is a fixed 40mm triple casement window modeled off the Vantage profile, all elements are fully extruded right down to the neoprene seals.  This file is quite large but excellent for adding that extra detail to your peoject.  I think i've managed to iron out all the kinks.  This window is fully parametric.  Two awning & one fixed pane - adjust awning window widths in element properties dialogue & this ultimately defines the fixed central pane.
3 Stars from 7 Votes
53580 downloads
4x fixed window
4x fixed window
stacked 2 fixed windows. completely parametric. can adjust width of each column of windows  and then height of each
3 Stars from 2 Votes
14636 downloads
4x2 Wood Transom Window
4 Stars from 1 Votes
8733 downloads
4x2 Wood Transom Windows
2 Stars from 7 Votes
15782 downloads
5'x5' Mullion window
Job specific- not panaramic
1168 downloads
5x2 Wood Transom Window
7072 downloads
5x2 Wood Transom Windows
5 Stars from 3 Votes
14267 downloads
5x5 Mullion Window
5x5 Mullion Window
Sorry, not parametric, but edible....
3467 downloads
6x fixed window
6x fixed window
14523 downloads
6x2 Wood Transom Window
8238 downloads
6x2 Wood Transom WIndows
2.5 Stars from 4 Votes
14118 downloads
8x5' window with mullions
Job specific- Hope windows style- Not parametric
1330 downloads
Page generation time: 0.7089
