43 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
adjustable downspout
4.5 Stars from 2 Votes
Product Version: Unknown
8535 downloads
Barn Fan
Barn Fan
This is a NON-parametric fan, but can be eddited easily
1201 downloads
Beirado Canto
Beirado Canto
Beirado Canto
4 Stars from 5 Votes
4092 downloads
Cimalha-Canto
Cimalha-Canto
Cimalha-Canto
2240 downloads
curved radius roof
curved radius roof
Curved metal roof, edit be front elevation and radius profile.
253 downloads
curved radius roof
curved radius roof
135 downloads
Downspout - Parametric
Revit 2009 downspout family. Allows control of eave depth and length of downspout. Basic, but gets the job done for elevations, and shows up as a rectangle in plan.
4.5 Stars from 6 Votes
26252 downloads
Downspout- Round - Parametric
This is a parametric downspout assembly.  It doesn't use a profile but the diameter is adjustable.
2337 downloads
Gable Louver Vent
Gable Louver Vent
This vent is designed to go at the top of a gable. It is formated for imperial units. Input the rise in inches under type properties and the pitch is calculated. Enjoy.
4 Stars from 9 Votes
17267 downloads
Glass & Steel Awning
This Glass and Steel Awning utilizes 3 components to set the piece up. All are generic wall based components so they will need a wall backing for them to work.
Awning Frames - is actually just the beam that sits against the wall
Awning Beams - is the module used to fill in the awning.
Awning Beams w-Tension Rods - To show the Tension rod structure at the ends and intermediate as you choose
The canopy's are parametric in "beam to beam" width and material properties but not in length or any others. If you want to modify them fix them in families or build your own ; )
4.5 Stars from 15 Votes
17609 downloads
Greenhouse Ridge Venting (Single)
Note: Cannot be smaller then 1'
Parametric
By Juul
1299 downloads
Lindab Downpipe System 125/87
Fully parametric Downpipe System object created in Revit Architecture 2016. It consists of a downpipe with a nozzle, bends and different outlet options.
For more downpipe system families and other families from Lindab, visit www.lindab.com/bim
For a complete free of charge LindabRevitLibrary, visit www.lindab.com/lindabrevitlibrary
2 Stars from 2 Votes
3887 downloads
Lindab Downpipe System 190/120
3480 downloads
Lindab Gutter System 125
Fully parametric Gutter System object created in Revit Architecture 2016. It consists of a gutter with optional gutter accessories on the left and right side of the gutter.
For more gutter system families and other families from Lindab, visit www.lindab.com/bim
1144 downloads
Lindab Gutter System 190
3.5 Stars from 9 Votes
5001 downloads
Lindab Gutter Types - 100, 125, 150 and 190
The gutters are available in 4 different sizes and comes in pre-painted steel in 10 different colors, also copper and Magestic.
For size and availability in your country, please visit your local Lindab website.
The Revit file contains gutter types that can be used directly using the built in gutter tool in Revit.
For more families from Lindab, visit www.lindab.com/bim
3 Stars from 3 Votes
4098 downloads
Lindab KFK 125 - Fascia Gutter Bracket - 2D
Fascia gutter bracket created in Revit Architecture 2016.
The family type is Detail Component.
For more rainwater system families from Lindab, visit www.lindab.com/bim
863 downloads
Lindab KFK 125 - Fascia Gutter Bracket - 3D
Fascia gutter bracket created in Revit Architecture 2016. It comes with a type catalogue specifying the available colors.
The family contains information about material quality and links to web tools.
The family type is Face Based Generic Model.
673 downloads
Lindab KFL 125 - Rafter Gutter Bracket - 2D
Rafter gutter bracket created in Revit Architecture 2016.
451 downloads
Lindab KFL 125 - Rafter Gutter Bracket - 3D
Rafter gutter bracket created in Revit Architecture 2016. It comes with a type catalogue specifying the available colors.
320 downloads
Lindab Rainwater System 125/75 Evaluation Version
Fully parametric Rainwater System object created in Revit Architecture 2016. This object is an evaluation version and will be replaced with final versions in September 2016.
Please send feedback to informationgateway@lindab.com and help us improving these objects. We will release the rainwater systems 125/87, 125/100, 150/87 and 150/100 in September 2016.
The family type is Speciality Equipment.
Prefered work order:
1. Component - Place a component
2. Placement - Place on work plane
3. Placement plane - Pick...
4. Specify a new work plane - Pick a plane - OK
5. Select the vertical face of the roof edge
6. Click a start and end point. From Left to Right.
1 Stars from 1 Votes
2512 downloads
Lindab RG 125 - Gutter Stop End - 2D
Gutter stop end created in Revit Architecture 2016.
473 downloads
Lindab RG 125 - Gutter Stop End - 3D
Gutter stop end created in Revit Architecture 2016. It comes with a type catalogue specifying the available colors.
528 downloads
Lindab RSK 125 - Gutter Joint - 3D
Gutter joint created in Revit Architecture 2016. It comes with a type catalogue specifying the available colors.
741 downloads
Lindab Snow Fence Pipe System
Fully parametric Snow Fence Pipe System object created in Revit Architecture 2016. It consists of pipes, consoles and fastening plates. The object handles product selection according to selected roof structure. It also contains complete specification information.
For more roof safety system families and other families from Lindab, visit www.lindab.com/bim
1211 downloads
Lindab SSK 125 - Adjustable Gutter Bracket - 2D
Adjustable gutter bracket created in Revit Architecture 2016.
749 downloads
Lindab SSK 125 - Adjustable Gutter Bracket - 3D
Adjustable gutter bracket created in Revit Architecture 2016. It comes with a type catalogue specifying the available colors.
477 downloads
Lindab Walkway System
Fully parametric Walkway System object created in Revit Architecture 2016. It consists of walkways, consoles and fastening plates. The object handles product selection according to selected roof structure. It also contains complete specification information.
1453 downloads
Pad style Snow Guard
2-3/8" wide by 1-1/2" high pad style snow guard
Product Version: Revit Building 9.1
2053 downloads
Parapet wall sweep
Parapet wall sweep
Use wall sweep command. The profile is inteded for wall coping parapet.  Customize to your project.
2646 downloads
Page generation time: 0.6197
