7 inch fluted |
Product Version: Revit Building 5.1
3614 downloads
9 Inch Pilaster Fluted |
5734 downloads
Rectangular architectural hollow column. Type Parameters: Depth and Width. Plus 6 instance parameters. |
19008 downloads
4 poles straight |
No rating |
Product Version: Unknown
609 downloads
A detailed parametric column used in Ludwig Mies' Barcelona Pavilion and Brno's Villa Tugendhat. Parameters are not 100 % functional, exceeding some might not work. You will see. |
No rating |
327 downloads
Its a rough draft of the base, the capital of the column is still needed. This is because each column has a different capital design. |
400 downloads
This is a 3D Family of Circular Mushroom Column. All constraints are editable. |
No rating |
Product Version: Revit Architecture 2019
617 downloads
No rating |
275 downloads
495 downloads
Simplified Roman Doric Order Column |
19235 downloads
SImple Clux Cloister Column for Fordham Medieval Studies Projects. |
968 downloads
Colonial Post Sweep Para Material |
3161 downloads
A generic model face family. |
No rating |
1122 downloads
Column |
13472 downloads
A Sloping Column I created for a project - Based on the generic M_Rectangular_Column |
1337 downloads
Craftsman Style exterior built up quad column with tapered concrete base and wood beam capital top. Has parametric adjustment. Our own design. |
16101 downloads
The column's height is adjustable, as is the radius of the top and bottom of the column, separately, as well as the individual widths and heights of top and bottom caps. The thickness of the column itself can also be adjusted. |
31275 downloads
conical column |
No rating |
4208 downloads
cool column |
No rating |
4873 downloads
Corinthian Column |
No rating |
8117 downloads
Corinthian Column |
No rating |
10768 downloads
Corinthian Column |
6522 downloads
Corner Pilaster |
No rating |
6171 downloads
Craftman style column |
No rating |
2992 downloads
THIS IS NOT MY COLUMN. I uploaded it and removed its constraints for those who don't know how to do that so that the column is actually ten feet and editable now. Rendered in medium (looks much better in high) Set the column hight to 6' 10" to make it right from the start |
10529 downloads
originally uploaded by tmohr, it is now entirely adjustable (to the best of my knowledge from how much I have tested the column) |
11864 downloads
This is a fully parametric Craftsman Column with both material parameters and height, width etc. |
8840 downloads
Craftsman Column - Parametric |
8557 downloads
Fully parametric for column size, materials, etc. Options for with or without a lower column base. |
No rating |
Product Version: Revit Structure 2020
1940 downloads
Here is the column used for my Craftsman Front Porch. Green Trim and stacked stone base. |
No rating |
2433 downloads
