52 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
A Room tag displaying department name
This is the modified version of original room tag.
5 Stars from 3 Votes
10464 downloads
addendum symbol
addendum symbol
addendum symbol
Product Version: Unknown
1448 downloads
Braced Panel Tag
Braced Panel Tag
Braced Panel Tag
1106 downloads
Door Rectangular Tag (Greek Family)
3 Stars from 2 Votes
2290 downloads
Door Tag
Door Tag
Circle with Opening Number and Window Number (Mark and Type Mark)
3704 downloads
Double Line Room Tag
This is a double line room tag.
1 Stars from 1 Votes
7273 downloads
Egress Door Tag
Egress Door Tag
Door tag for showing egress width
3.5 Stars from 2 Votes
2991 downloads
Egress Door Tag
Egress Door Tag
Shows the following:
  1. Mark (auto)
  2. Width (auto in inches)
  3. Occupancy count (manual)
  4. Required Width (auto in inches)
You must link in Shared Parameters into project and create parameters for used wall types (similar to example.)
2.5 Stars from 3 Votes
2124 downloads
Egress Width Tag with Direction
Egress Width Tag; Calculates the required width for doors and stairs based on Occupant loads. Also, has four options for Direction of Egress. Enter the Occupant Load and the Code required width per person and it will show the required total width. Instance parameter, for each separate location. Includes a place holder for Actual Width.
Product Version: Revit Architecture 2019
588 downloads
Elevation Tag - 8 Interior Views
2.5 Stars from 2 Votes
3049 downloads
Etiqueta para Indicación de Nivel (Vista de Alzados)
Etiqueta para cambiar la clásica figura circular de los niveles en los alzados por una flecha que indica Nivel
5286 downloads
Etiqueta para Puerta
Etiqueta para indicar en puertas el Ancho de vano y la altura del Dintel de una puerta cualquiera colocada en Revit Architecture 2012
1589 downloads
FAV Elevation Tag
FAV Elevation Tag
Elevation tag that can have a different page number per elevation triangle.  How to load into project:
With this elevation tag family file open and a project file open click on load into project.  Then in the project file, Manage Tab, Addtnl Settings, Elev Tags, it should be in the value drop down box - choose it. Then, duplicate a new type for this new tag.
When you do a new elevation, edit the type and in the Value box of Elevation Tag Graphics choose the little box in the upper right corner that shows up when you select this Value box. Then at the next window choose the duplicated name from the type drop down. FAV Elev Mark or the custom name you created.
3060 downloads
Identificador de Janela Norma NBR 6492
Window tag Brazilian standard NBR-6492
2435 downloads
Identificador de Porta Norma NBR 6492
Door tag Brazilian standard NBR-6492
1 Stars from 2 Votes
2916 downloads
Keynote - Octagon
Keynote - Octagon
Keynote - Octagon
2.5 Stars from 6 Votes
1723 downloads
Keynote - Pentagon
Keynote - Pentagon
Keynote - Pentagon
1035 downloads
Modifiable Finish Tag
this finish tag includes finish information for floor, base and wall. Each can be modified by instance and can be placed on a finish plan
4618 downloads
NCS 4.0 Exterior Elevation tag
This is a NCS 4.0 Exterior Elevation tag with the correct 5/8" dia circle built with Revit 2011
10174 downloads
NCS 4.0 Interior elevation tag
This is a NCS 4.0 Interior Elevation tag with the correct 5/8" dia circle built with Revit 2011
7385 downloads
NCS Door Tag
NCS Door Tag
This is a door tag based off of NCS 3.1 where the Door number is Parallel to the door leaf.
10607 downloads
NCS Room Tag with basic Finish Info
NCS Room tag that has a type that includes the room basic finish information
3039 downloads
note block tag with joist span
Insert as symbol to indicate structural framing span direction and member tag, populate a note block with framing information (e.g. 2x10@16")
Set length of arrow as actual span.
Set view scale in feet/in (1/4"=1'-0" represented as scale = 4'-0", 3/16"=1'-0"  as 3'-4")
374 downloads
OCCUPANCY LOAD SCHEDULE, CODE COMPLIANCE PLAN
This is the finished Facility Occupancy Load Schedule and Egress Plan. This is automated to calculate the occupant load based on the type of area then use that to calculate occupant load.
There are 2 tags. 1 for rooms, 1 for egress doors.
There are 4 schedules
1.      DOOR EGRESS SCHEDULE
2.      FACILITY OCCUPANCY SCHEDULE
3.      ROOM OCCUPANCY COMPARE SCHEDULE
4.      SPACE OCCUPANCY CLASSIFICATION
There is one sample Model.
Steps:
1.      Copy the schedules and tags to your current project.
2.      Open the Room occupancy compare schedule
3.      Select what type of area you see fit.
4.      Type in 0 sf for “NON CALCULATED ROOM AREA” to calculate occupants
5.      Manually type in tag value to match calculation to populate the room tag.
6.      Place the facility schedule on the code plan sheet.
7.      Place the Door egress schedule on the sheet too.
8.      Place all your room tags
9.      Place your egress door tags on 1 exit way door only per egress area
10.   Make a note of how you want to number your egress areas. ( I usually go clockwise from upper left to lower right)
11.   Fill in the Egress area for each room in the properties field. ( You can multiple select rooms at the same time and type in the value for all at once, use your filter)
12.   The Facility Schedule will populate.
13.   Type in the Occupant value to the Door egress schedule. Make sure they match. Hide Door egress schedule.
You’re done. Or pretty close J #JustinDesigns3D JustinDesigns3D@Gmail.com
3776 downloads
Octagon Keynote
Octagon Keynote
Octagon Keynote
Product Version: Revit Building 5.1
863 downloads
Octagon w/ Trim
Octagon w/ Trim
A revit 7 version of the popular octagonal shaped window
1.5 Stars from 3 Votes
976 downloads
Panel Name and Circuit Number Wire Tag
Wire tag that displays panel name and circuit number with a dash in between. Labels are justified so that the dash remains in the center.
3 Stars from 1 Votes
1053 downloads
Pentagon Keynote
Pentagon Keynote
Pentagon Keynote
803 downloads
Plumbing Fixture Tag
4450 downloads
Property line segment tag
Could not find one of these so here it is, a property line segments tag. It rotates to the line you tag. Provides boundary dimension in metres to 3 decimal places and bearings in degrees, minutes and seconds
2.5mm text.
4029 downloads
Page generation time: 0.6033
