An advanced pool that was created in Revits Architecture 09' |
5582 downloads
Product Version: Unknown
1517 downloads
I built this to get in a planners face! garden trellis, not adjustable, didnt see the need for it? |
Product Version: Revit MEP 2012
19855 downloads
No rating |
1559 downloads
A fully parametric box bridge for road with brick cutoff wall around raft foundation. Thickness of walls, slab,raft & wing walls change as per clear span & height. |
3049 downloads
Product Version: Revit Building 8
6834 downloads
24' Above Ground Swimming Pool
5' 5" High
4' High water |
15455 downloads
2D Football Field |
Product Version: Revit Building 5.1
3831 downloads
A fully parametric box bridge for road with brick cutoff wall around raft foundation. Thickness of walls, slab,raft & wing walls change as per clear equal span & height. |
2644 downloads
3 point-Tensile Shade-Adaptive |
Product Version: Revit Structure 2020
1528 downloads
20556 downloads
3D Football Field |
7863 downloads
No rating |
2676 downloads
fence used in residential projects, 50% transparent. Used as a component, not a railing. Parametric in length and can adjust the number of posts and material
2013 |
21780 downloads
8' Gazebo based on a design that I found online. Materials are parametric. Visibility parameter for pier foundation. |
25966 downloads
abstract copper sculpture |
39897 downloads
ADA parking space |
No rating |
7432 downloads
ADA parking space |
14847 downloads
Adjustable mounting and pole heights with both standard pole mount and wall mount types |
No rating |
2042 downloads
AGRV_PRKG_Car-AD-Dropoff_無障礙汽車下車區
Accessible Design Parking Dropoff and strip with DIM & Material parameters and dimension Guide
All size is basic on Taiwan architecture regulation.
Visit our website AgileRevit.com for more families |
No rating |
593 downloads
AGRV_PRKG_Car-AD_無障礙汽車停車位
Accessible Design Parking Space and strip with DIM & Material parameters and dimension Guide
I use shared parameter so you can easily count them using schedule.
No rating |
327 downloads
AGRV_PRKG_Car_汽車停車位
Parking space and strip with DIM & Material parameters and dimension Guide
No rating |
627 downloads
AGRV_PRKG_Motorcycle-AD_無障礙機車停車位
Accessible Design Motorcycle Parking Space and strip with DIM & Material parameters and dimension Guide
No rating |
285 downloads
AGRV_SITE_BifurcationArrowsA_分岔箭頭A
BifurcationArrows (2 Direction) with DIM & Material parameters and dimension Guide
尺寸根據中華民國交通部高速公路局交通工程手冊標誌標線篇(第三章)_定稿版1025
No rating |
159 downloads
AGRV_SITE_BifurcationArrowsB_分岔箭頭B
No rating |
138 downloads
AGRV_SITE_BifurcationArrowsC_分岔箭頭C
BifurcationArrows (3 Direction) with DIM & Material parameters and dimension Guide
No rating |
114 downloads
No rating |
101 downloads
AGRV_SITE_ContinentalCrosswalkStripe_枕木紋行人穿越線
CrosswalkStripe with DIM & Material parameters and dimension Guide
No rating |
219 downloads
AGRV_SITE_DelfectionArrow_弧形箭頭
DelfectionArrow with DIM & Material parameters and dimension Guide
No rating |
179 downloads
AGRV_SITE_StraightArrow_直線箭頭
StraightArrow with DIM & Material parameters and dimension Guide
No rating |
212 downloads
