58 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 36 | 1 | 2 | 3 | 4 | 5 Next >>
"Bell' Pendant by Mark Braun from Northen Lighting
Distance from ceiling and materials - parametric.
4 Stars from 17 Votes
59242 downloads
"Jelly Jar" Light Fixture
Product Version: Revit Building 9.1
5862 downloads
15 Simple Lamp 2D
15 Simple Lamp 2D
Simple lamp made from an flat surfaces and lines. Perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator.
3374 downloads
16 Simple Lamp 2D
16 Simple Lamp 2D
1477 downloads
2 Tier Glass Chandelier
Lights Only Work Rendered
3 Stars from 6 Votes
Product Version: Unknown
22545 downloads
20 Simple Lamp 2D
20 Simple Lamp 2D
Simple lamp made from flat surfaces and lines. Perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator.
2254 downloads
3 lamp strip fluorescent
21321 downloads
3 Light Chandelier
3 Light Chandelier
Chandelier with adjustable height and slope for ceiling. Has 3 individual light sources. User may need to adjust the lighting parameters for rendering. RAC2012
4.5 Stars from 5 Votes
32984 downloads
3-lamp stainless steel ceiling mounted track light
4 Stars from 13 Votes
47945 downloads
4' Dia. Dome Light
4' Dia. Dome Light
Model off of the Mark Architectural Lighting Magellan Series. Very Detailed
19084 downloads
5 Light Bell Glass Chandelier
BASED ON HISTORIC LIGHT FIXTURE. LIGHT SOURCE NOT ACTUALLY INSIDE GLOBES.  LENGTH CAN BE ADJUSTED.
4 Stars from 4 Votes
40271 downloads
5" Clear Specular Downlight
4 Stars from 16 Votes
70263 downloads
52" Surface Ceiling Fan Retro look
52" ceiling Fan with Sweeping fins. Material fully Modifiable. Let me know what you think. Haven't rendered this one yet eather.
30348 downloads
5A 120V Surface Mounted Exit Sign - Parametric
With Parametric Elevation & Annotation Flipping
5 Stars from 3 Votes
9559 downloads
8-Lt Minimal Traditional Pendant Chandelier
Based from custom manufacturer Two Hills Studio's CB1C Chandelier at its maximum dimensions.
https://twohillsstudio.com/portfolio/chandelier-cb1c/
Face Based Model howver the Ref. Level is at the bottom of the fixture so the bottom of the fixture will be at the floor/ref level of your model. Heights are changed with the  instance paramters for the "bottom of fixture" and "the pendant drop."
The sub family does not have a photometric parameter for an .IES file
4 Stars from 1 Votes
Product Version: Revit Structure 2020
5738 downloads
A Suspicious Lamp
A Suspicious Lamp
I dont know about this...
3.5 Stars from 4 Votes
1554 downloads
A60-P Pendant lamp
A60-P Pendant lamp
Download: http://bimobject.com/glamox/product/a60-p
This is an example of one of the many objects available from this manufacturer on the BIMobject Cloud. Click on the link to find so many more objects which are free for all designers from around the world to use. We also have an amazing app which enables you to access our complete library directly from within your BIM software
Revit app: http://info.bimobject.com/revit-app
The light fixtures organic form seem like small pebbles on a beach. The A60 is produced in three sizes. All three have unique shapes and proportions. The black or white acrylic outer shell have a high glossiness. The inner shell is available in a variety of colours which creates elegant kontrasts.
1 Stars from 1 Votes
8600 downloads
Adjustable Height Chandelier
Height parameter included as well as material parameters. Should act as a ceiling based fixture. REVIT 2023
1131 downloads
Alhambra Contemporary Ceiling Light
First one of the day....
Yet another Ceiling pendant. this time a contrast of wood and ceramic shade. All materials are changable along with the ceiling drop height.
Face based family.
Enjoy
16838 downloads
Alt Taupe ceramic ceiling light
Another quickly modelled Ceiling Pendant.
Again, ceiling drop and ceiling rose, Shade and wire connection all changable in materials.
Size of shade is 420dia x 260h.
21181 downloads
ANP M714-E6-200GLGC_Gooseneck light
Gooseneck light for exterior applications. This model has the shade rotated 90 degrees as it was made for some exterior signage on either side.
No light source or photometrics here, just a simple generic model fixture for representation purposes.
8871 downloads
Antique Door Lamp Revised
Fixed wall offset problem.
5 Stars from 2 Votes
8014 downloads
APOLLO FLOOR LAMP
APOLLO FLOOR LAMP
This revit model has been created using available DWG information.
Manufactured by: Restoration Hardware
Files: .rfa (Revit 2019 +)
FREE FOR 24 HOURS // DOWNLOAD AT THECREATIVEROUTE.COM
Product Version: Revit Architecture 2019
760 downloads
APOLLO FLOOR LAMP
APOLLO FLOOR LAMP
1906 downloads
Arc Modern Floor Lamp
Arc Lamp. All materials can be change
28390 downloads
ArcĀ®
ArcĀ®
Construction: Formed aluminum constructio,Precision anodized reflectors and Completely sealed optic chamber
Lamping/Optics: H.I.D. lamping 50w to 150w, Type II distribution and Cutoff and Full Cutoff classifications.
Design Options: Choice of three architectural mounting arm styles, Choose flat or sag tempered glass lens, Two sizes offer design compatibility from street/parking lot to walkways.
Finish: Multi-step cleaning and sealing process and High quality polyester powder coat finish.
Certifications: NRTL listed, ASTM and PCI for finish, and IDA-Approved "Dark Sky Friendly" (with Flat Lens)
This product features IDA-Approved "Dark Sky Friendly" Full-Cutoff optics.
4 Stars from 9 Votes
19604 downloads
Arne Jacobsen floor lamp
ARNE JACOBSEN floor lamp
10837 downloads
Arne Jacobsen Lamp
Arne Jacobsen Lamp
ARNE JACOBSEN table lamps
6097 downloads
Arne Jacobsen wall lamp
ARNE JACOBSEN wall lamp
14533 downloads
Arod ikea desl lamp
Arod ikea desl lamp
Product Version: Revit Structure 2017
2367 downloads
Page generation time: 0.7922
