Pedigo floor pedestal. Two sizes available. |
No rating |
1476 downloads
This is a generic 32 track Mixing console with ballparked sizing |
No rating |
1875 downloads
No rating |
Product Version: Revit Systems 2
1463 downloads
5 way switch Decora style Light switch |
No rating |
2977 downloads
Revit 2018 |
No rating |
Product Version: Unknown
325 downloads
Two Wheel Bench Grinder |
No rating |
2340 downloads
Line-Based Parametric Cable tray that I created. Improve and re-post! Hopefully it won't break! (Can't do super small segments, unless you turn down the MAX SUPPORT SPACING param, and then you'll have more supports than you want, probably should add an if/then when segment is too short.) |
Product Version: Revit MEP 2009
8467 downloads
Camera ceiling base |
Product Version: Revit MEP 2013
8028 downloads
BIG LaserPrinter |
Product Version: Revit Building 8.1
7111 downloads
Face Based external CCTV Camera with housing and bracket. Angle parameter rotates symbol as well as geometry. |
Product Version: Revit MEP 2011
16414 downloads
Ceiling Fan With Light,
Adjuestable Width & Color of Fan |
No rating |
8732 downloads
Ceiling fan acutally created in Revit |
No rating |
6603 downloads
Ceiling fan manufactured by Masterfan
56 inches
(set to 70 inches custom length)
Satin aluminum finish |
No rating |
Product Version: Revit Structure 2019
2044 downloads
No rating |
9055 downloads
Version 1.0
Ceiling Mounted WAP - Face Hosted
Make any suggestions you'd like. |
8509 downloads
I have been working on this family for several months... It is fully parametric, has a instant label parameter. There is a symbol for locating a componet at a special height (re: set at 42" symbol). I often label a swich componets, for example: Fan, lights (#of lights), dimmer. The text type has transparent background. |
5246 downloads
Modeled from a manufacturers website dimensions. Materials are able to be changed. |
Product Version: Revit Structure 2020
2167 downloads
Product Version: Revit MEP 2018
207 downloads
No rating |
218 downloads
No rating |
255 downloads
No rating |
222 downloads
578 downloads
No rating |
367 downloads
No rating |
354 downloads
No rating |
23049 downloads
Fully editable model and symbol. |
No rating |
Product Version: Revit MEP 2012
2724 downloads
Revit 2018 |
No rating |
103 downloads
This Family combines a fully realistic renderable Outlet and the capabilities of a MEP Family. Each Receptacle can be scheduled and tied to in MEP. |
3291 downloads
4140 downloads
Product Version: Revit MEP 2010
764 downloads
