21 Users Online (19 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 6 | 1 | 2 | 3 | 4 | 5 Next >>
10 - Perforated Return Grille
The 10 Series Perforated Return Grille is designed to match perforated supply diffusers to provide a coordinated aesthetic throughout a space. Featuring 51% free area, the 10 Series grille maintains low noise and pressure drop in high capacity return applications.
Product Version: Revit MEP 2020
328 downloads
12x12 Supply Diffuser w/ auto-size connector
Uses IF statements to automatically size duct connector based on CFM. Fully adjustable CFM ranges for 4" to 8" sizes. Use one family with one type, no need to change to a new type with a different connector size when you change CFM. Non-hosted family.
2 Stars from 1 Votes
Product Version: Revit MEP 2012
3820 downloads
150 - Heavy Duty Louvered Supply Grille
Ideal for industrial applications, the 150 Heavy Duty Louvered Supply Grille features individually adjustable blades spaced on 1.5 in. centers to accommodate large air volumes and provide directional control suitable for spot heating and cooling.
368 downloads
23/30 - Airfoil Supply Grille
Price Industries Airfoil Suply Grille
The 20/30 Series Airfoil Supply Grille features premium quality, extruded aluminum construction. Individual blades are fully adjustable and the airfoil shape helps to reduce turbulence, leading to low sound and pressure drops.
119 downloads
24x24 Supply Diffuser w/ auto-size connector
Uses IF statements to automatically size duct connector based on CFM. Fully adjustable CFM ranges for 6" to 15" sizes. Use one family with one type, no need to change to a new type with a different connector size when you change CFM. Non-hosted family.
1 Stars from 2 Votes
4290 downloads
3.5-4 ton Bard Wall Hung HVAC
Bard Wall Hung Unit, modeled with high detail. Does add a bit of MB's to your file. (Extremely Non-Parametric, sorry!)
5 Stars from 2 Votes
2360 downloads
300 - Heavy Duty Airfoil Supply Grille
Price Industries Heavy Duty Airfoil Grille
The 300 Heavy Duty Airfoil Supply Grille is well-suited to industrial applications, with individually adjustable blades and wide blade spacing for maximum free area and the ability to spot heat and cool.
289 downloads
4-6"Ø Engine Exhaust Duct Silencer
1814 downloads
500FF/600FF - Filter Frame Louvered Return Grille
Price Industries Louvered Filter Frame Grille
The filter frame is intended to be incorporated into a conveniently serviceable return air filtration system and is designed for recirculating air systems
97 downloads
60/70 - Airfoil Return Grille
The 60/70 Series Airfoil Return Grille features premium quality, extruded aluminum construction, resulting in clean, crisp detailing to blend with almost any architectural surrounding. The heavy extruded aluminum blades are fixed at a 45° angle for minimal see-through.
Product Version: Unknown
151 downloads
700 - Stainless Steel Louvered Grille
Price Industries Stainless Steel Louvered Grille
The 700 Series Louvered Grille makes uses adjustable (supply) or fixed (return) blades to control airflow and provide a supply or return unit with minimal see-through.
241 downloads
AC Thru wall Unit
AC Thru wall Unit
AC Thru wall Unit
4 Stars from 11 Votes
13561 downloads
Aldes Ceiling Register Box
Aldes CERB Exhaust & CSRB Supply standard and high pressure option. Separate grille included. Created types for most CFM ranges available up to 8" CAR.
Product Version: Revit MEP 2017
768 downloads
Aldes CR3 CAR Wall Register
Aldes Wall Register with constant airflow regulartor. 4-10"Ø sizes, regular and with Fire Damper.
36 downloads
Aldes Parallel Zone Inline Register Terminal PDIL
Aldes PDIL Paralel Zone Damper Terminal with Airflow Regulator.
Product Version: Revit MEP 2019
122 downloads
Aldes Single Zone Inline Register Terminal SDIL
Aldes SDIL Single Zone Damper Terminal with Airflow Regulator.
56 downloads
Aldes Zone Inline Register Terminal IL-2 With Bottom Access
Aldes IL Zone Damper Terminal with Airflow Regulator with Bottom Access. Allows control of min & max flow rates.
181 downloads
AMCD - Adjustable Modular Core Directional Diffuser
Price  Industries Adjustable Modular Core Directional Diffuser
The modular core directional diffuser (AMCD) supplies large volumes of air at low sound levels and pressure drops. The modular core design allows for easy, tool-free reconfiguration of the discharge pattern and easy access to ductwork for maintenance. With a tight horizontal discharge air pattern, even at low air volumes, the modular core directional diffuser is well suited to VAV applications.
71 downloads
Angle bar duct support_fixed width
The object is fabricated to support ducts especially when wall mounted bracket is not relevant
162 downloads
ATG - Aluminum Transfer Grille
Price Industries Aluminum Transfer Grille
Transfer Grilles offer the largest free area possible with the option of a sight-proof or light-proof core. Transfer grilles are designed for use in doors and partitions to allow for smooth transfer of air between spaces. Such spaces include storage rooms and restrooms.
75 downloads
Bard 3 Ton Vertical Wall Hung HVAC
This is my 1st attempt at a family. I could not get the electrical connection to move to the right place. I have the supply and exhaust correctly placed.
4183 downloads
BARD 3-Ton 10KW
BARD 3-Ton 10KW
I made some changes, Has correct Loads and air is blowing right Direction.
533 downloads
Baseboard
Baseboard
Baseboard
4129 downloads
Bathroom Ceiling Fan
29684 downloads
10573 downloads
Belt drive Centrifugal roof exhaust fan
Generic base component. Not parametric.  Model includes a 12" roof curb.
Product Version: Revit Structure 2018
2002 downloads
BTU METER (BRITISH THERMAL UNIT METER)
IT APPLICABLE FOR A RANGE UPTO 12MM TO 1000MM ABOVE.
FULLY PARAMETRIC WITH ONE OPERATING PARAMETER.
MATERIALS APPLIED.
ELECTRICAL CONNECTIONS GIVEN
NOTE:ITS NOT AS PER STANDARD JUST AN GENERIC MODEL
MODEL INFO NOT ADDED.
1277 downloads
Canopy Range Hood
Canopy Range Hood
Wall mount canopy range hood, parametric material
3 Stars from 5 Votes
37098 downloads
Carrier-5 TON-V-AHU_M-FZ4A
A Carrier® fan coil can be a core component of your comfort system. If you could look under the hood, you’d see what drives the performance: a serious commitment to quality. Certain fan coils feature ECM blower motors for optimized airflow, comfort and efficiency. Our Infinity® and Performance™ models step it up with variable-speed air delivery for extra efficiency, quieter operation and even, consistent indoor temperatures. For lasting durability through corrosion protection, the indoor coil includes our high-tech composite base pan with its integrated, sloped drain. The base pan promotes positive drainage to help reduce opportunities for growth of airborne irritants. To ensure maximum reliability and energy-efficient operation, our thermostatic expansion valve (TXV) maintains proper refrigerant flow as pressure and conditions change. Of course, this is the type of excellence you expect when you turn to the experts – Carrier.
Product Version: Revit MEP 2018
627 downloads
ceiling a/c
ceiling a/c
5839 downloads
Page generation time: 13.3434
