72 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 1 |
ACE-B
ACE-B
Product Version: Revit MEP 2010
825 downloads
Avco - SS Ball Valve - 1100 Series Flg x Flg
Available Sizes:
1/4" | 1/2" | 3/4" | 1" | 1 1/4" | 1 1/2" | 2" | 2 1/2" | 3" | 4"
Product Version: Revit MEP 2015
628 downloads
Avco - SS Ball Valve BW x BW - ETO 2100 Series
Available Sizes:
1/2" | 3/4" | 1" | 1 1/2" | 2" | 3" | 4"
1128 downloads
Avco - SS Ball Valve Flg x Flg - Class 150 9100 Series
Available Sizes:
1/2" | 3/4" | 1" | 1 1/4" | 1 1/2" | 2" | 2 1/2" | 3" | 4" | 6" | 8" | 10" | 12"
*Note: Do not use This Family for 1.25" - Use Series 1100
1 Stars from 1 Votes
849 downloads
Avco - SS Ball Valve NPT x NPT - 1100 Series
Available Sizes:
478 downloads
Avco SS 3-Way Ball Valve
Available Sizes:
1/2" | 3/4" | 1" | 1 1/4" | 1 1/2" | 1 3/4" | 2"
664 downloads
Boss Dosing Pot 6L
Boss Dosing Pot 6L
Boss 6L dosing pot
fully parametric with all connections
4.5 Stars from 2 Votes
Product Version: Unknown
1603 downloads
Brazed Plate Heat Exchanger
Generic model. Dimensions and pipe connection sizes, locations, length etc. fully parametric. Adjust based on selection.
Product Version: Revit MEP 2017
734 downloads
Butterfly valve
Butterfly valve
2.5 Stars from 3 Votes
2313 downloads
Centrifugal Pump
Centrifugal Pump
Change To Any Desired Size
Easy To Edit
5920 downloads
Enwamatic Side Stream Filter
fully parametric model created from 3D DWG
Product Version: Revit MEP 2013
1050 downloads
FDI - AF Butterfly - Balance Valve
Model - AF
Type - Butterfly Valve
Sizes - 2", 2.5", 2", 4", 5", 6", & 10"
Notes: This Family has a lookup table, as well as a type catalogue.
840 downloads
Model - AF
641 downloads
FDI - UA - Balancing Valve w/ Unions
Manufacturer - Flow Design Inc.
Model - UA
Sizes - 0.5", 0.75", 1", 1.5", & 2"
584 downloads
FDI - UP - Unions
FDI - UP - Unions
Model - UP
Sizes - 0.5", 0.75", 1", 1.25", 1.5", 2" & 2.5"
198 downloads
FDI YC Ball Valve Wye Strainer and Union
Model - UP
Sizes - 0.5", 0.75", 1", 1.25", 1.5", & 2"
Notes - Has a Toggle On/Off parameter to control W/, or W/O Strainer.
677 downloads
Finned Tube for Heating
Finned tube for use in parking garages, etc.
Product Version: Revit MEP 2018
385 downloads
Flexible Braided Metal Hose Connector 2"-14"
Metraflex model SLP Parametric
Product Version: Revit MEP 2012
1882 downloads
Grundfos Pressure Vessel
Grundfos 300L pressure vessel
correct dimensions and connection sizes
2147 downloads
Hoffman FFT105H
Hoffman FFT105H
A Float and Thermostatic Steam Trap.
*to change sizes use the "Diameter" parameter in the properties menu.
528 downloads
In-line-Swivel-Thermometer
-There two different types, that controls the size.
- Under "segments and fittings" section, you can turn on what angle you want either 90,45, or straight, with the check boxes in the parameter menu.
2 Stars from 2 Votes
1006 downloads
Lakos STS-36 Sand Filter
1752 downloads
Pressure Gauge w/ 1/4" Ball Valve Adjustable & Siphone
An update OOTB Pressure Gauge with 1/4" "Instance" Threaded Ball Valve. 1/4" Ball Valve is a nested family within the family so one could utilize a shared family for scheuling purposes. When the Ball Valve instance is not selected connection point is adjusted accordingly.
Stem and Dial and ND is adjustable.
Siphone geometry is within the family but not visible.
Product Version: Revit MEP 2019
2180 downloads
Rectangle Duct Horizontal Connection
Rectangle Duct Horizontal Connection to round duct
2863 downloads
Rectangle Duct Horizontal Elbow
Rectangle Duct Horizontal Elbow 45 degree curve
3630 downloads
Rectangle Duct Horizontal Elbow 90 degree curve
4 Stars from 1 Votes
4839 downloads
Synergy - 3D
Synergy - 3D
Geothermal-Water Furnace
http://www.waterfurnace.com/products.aspx?prd=Synergy3D
7003 downloads
Tower Flow TFSP-0200 SEPERATOR PACKAGE
Tower Flow Seperator package with pump, tank and panel. Electrical Panel was made by someone else and pump was also made using Solidworks by someone else.
2 Stars from 1 Votes
2135 downloads
xxx
xxx
xxxx
66 downloads
Zehnder CV3
Zehnder CV3
Downloaded from https://www.zehnder.co.uk/downloads/csy
30 downloads
Page 1 of 1 |
Page generation time: 0.6523
