39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 1 |
04 23 00 - Glass Block Unit
7 3/4" x 7 3/4" x 3 1/8" - Parametric
3.5 Stars from 16 Votes
Product Version: Unknown
27126 downloads
24x16 Running Bond Stone
3 Stars from 7 Votes
16287 downloads
24x16 Stone with mortar
4.5 Stars from 8 Votes
12800 downloads
24x4 Running Bond Stone
4 Stars from 8 Votes
11126 downloads
24x4 Stone with mortar
7976 downloads
2x12 Running Brick
2x12 Running Brick
2x12 Running Brick
4 Stars from 9 Votes
11134 downloads
2x2 Brick Pattern
2x2 Brick Pattern
2x2 Brick Pattern
2.5 Stars from 7 Votes
16959 downloads
3x3 grouted brick
3x3 grouted brick
3x3 grouted brick
3.5 Stars from 4 Votes
8628 downloads
4x16 Block
4x16 Block
4x16 Block
2.5 Stars from 3 Votes
8599 downloads
4x16 CMU or Block
4x16 CMU or Block
4x16 CMU or Block
3072 downloads
8 inch mortar joint concave
2482 downloads
8x16 block
8x16 block
8x16 block
3 Stars from 2 Votes
7370 downloads
8x16 cmu block with mortar
6910 downloads
8x8 blocks
8x8 blocks
8x8 blocks
4474 downloads
Ashlar Stone Pat
Ashlar Stone Pat
4 Stars from 10 Votes
10943 downloads
Block 4x16 running bond
4x16 running bond pattern
5 Stars from 2 Votes
2020 downloads
Brick & Metal Landscape Fencing
Brick Pilasters and Lower Wall Panel with Metal Insert
2839 downloads
CMU corner block
1 Stars from 1 Votes
Product Version: Revit Building 9.1
2479 downloads
CMU corner split face in plan
2011 downloads
CMU to Brick Tie - Detail Component
This family is to be used in drafting view.
It is a side view of a brick tie, when attaching to a CMU wall.
You can adjust the brick tie to catch the difference between the CMU and brick course if needed.
2908 downloads
Curved Brick Lintel
Curved Brick Lintel
Parametric Brick arch which auto adjusts based on brick size, opening width and spring height
5 Stars from 5 Votes
6144 downloads
Detail Component- Bullnose CMU Block
A bullnose block in section- nominal 8x8. I was searching for this component and couldn't find one, so made one for myself and hopefully it helps someone else.
2762 downloads
Footing and Big Foot Pad
adjustable Sono Tube and Big Foot Pad
2074 downloads
Glass Block
Glass Block
3395 downloads
micro house
micro house
smaller residences for living purpose with basic requirements
3690 downloads
micro house
331 downloads
Obelix block parametric
50 downloads
Vanity-Cold_Spring_Granite-Stone-Square_Front_Edge-Single_Sink
www.coldspringgranite.com/BIM_Families/Family_Detail/Countertop_-_Vanity_Stone_Panels_with_Single_Sink_Cutout/?r=bim
1735 downloads
Wall coping tile Couvre mur terre cuite
467 downloads
Wanker block parametric
41 downloads
Page 1 of 1 |
Page generation time: 0.6438
