Here's an updated version of the box of doughnuts with the right size and measurments for use!
I'll be design more components!
food , doughnut , box |
Product Version: Revit Structure 2017
10647 downloads
WWW.REVITOBJ.COM
WWW.REVITOBJECT.IR |
2974 downloads
Hollow clay blocks |
No rating |
Product Version: Revit Structure 2018
321 downloads
Tall kitchen trash/recycling receptacle |
15096 downloads
No rating |
183 downloads
Product Version: Unknown
15895 downloads
339 downloads
No rating |
178 downloads
No rating |
230 downloads
2D business man I made for one of my projects. I have seen a lack of people on Revitcity, so I figured I would upload this one. I took the 2D person up a notch. Suit, shirt and tie colors are changeable.
Done in Revit 2014 |
34426 downloads
Colors are changeable
12131 downloads
3d Gridline and 3d Dimension is used for clash detection model for enscape, lumion, twinmotion and many other clash detection software. |
No rating |
560 downloads
Create By Mohamed Mostafa
at Revit 2015
My Channel Youtube
https://www.youtube.com/c/MohamedMostafaAlsharif
My Page in FaceBook
https://www.facebook.com/3dquality |
No rating |
1951 downloads
The pattern is currently scaled to 3x12, if you need something larger or smaller change the import scale. For example, a 6x24 tile would be imported at 2.00 scale.
To rotate the pattern to 45 degrees, fill a region then rotate using the rotate tool and then edit the boundaries to fix the edges.
If you are having trouble downloading the file, right click on the page of code and do a save as file. Set the type to all files and change the .txt to .pat. If .pat is already selected you may still need to erase it and type it in manually. If you save the file and it appears on your computer as a text file that opens with notepad, save that file as a .pat file and Revit should be able to import it as a hatch pattern. |
4915 downloads
I used this to quickly infill areas of paint striping in a parking lot. |
No rating |
2696 downloads
8" Hexagon .pat file can be used in revit and other supported software.
How to use in revit
1.Copy the text. open note pad. Paste it and save with .pat(dot pat) extension
2. Open material tab then surface pattern then model pattern-- New--load the pat.
4881 downloads
Human figure female - Flat 3d human for renderings - 3d people - part of my 3d entourage collection flat-woman-13C
www.3dentourage.com |
34282 downloads
A wood crate with metal frame that is full parametric in height, length, depth, and materials can be change for framing and the crate surface, so it can be a wood crate or any type of crate as need. Fruits are not included. Enjoy! |
20225 downloads
Obsolete |
No rating |
286 downloads
2D person on a wheel chair! Simple and useful, I couldn't find it here so I made mine. |
7201 downloads
Duck with a mission. |
5866 downloads
REALLY GOOOOOD |
3624 downloads
200,000 lb capacity Commercial Aircraft tie down |
3365 downloads
Non parametric alcohol bottle. You can use any image for the label. Use it to enhance renderings. |
No rating |
Product Version: Revit Architecture 2019
7366 downloads
Alienware Aurora ALX desktop
i can produce other objects instead of halo stuff and here is the proof |
1962 downloads
Drawn in revit 2021
No rating |
2341 downloads
Android Mascot |
No rating |
256 downloads
Heres Rhino model i found and converted to Revit to use in a project of mine. It material can be changed. It just under 6-8" tall but as with any model from AutoCAD can be scaled to fit your needs. Thought others might be able to use it to. Let me know what you all think and if its helping any? |
21190 downloads
Maçã |
4274 downloads
2D Arab man wearing a kandora. |
No rating |
2137 downloads
