55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
12 cu.m. Skip
12 cu.m. Skip
I needed a model of a skip and could not find one. Created this from data obtained on the net. Not perfect, but does the trick and shows intent.
Product Version: Unknown
2643 downloads
30" Diameter Geopier
1412 downloads
3D Grass Family
3D Grass Family
I created this grass family for Revit (2015-2019)
Watch this video to know how to use this family
https://www.youtube.com/watch?v=63YDRQbql8o
My blog (where I share free Revit practice files): www.cadneeds.blogspot.in
My YouTube channel: MTH Revit Tutorials
1 Stars from 1 Votes
26316 downloads
3D Plant
3D Plant
Not Parametric
4 Stars from 20 Votes
96347 downloads
Adaptive Landscape Seating
Adaptive Landscape Seating.
Get Complete project file here:
  https://youtu.be/nziK_tX5nAw
4 Stars from 1 Votes
Product Version: Revit Structure 2016
1902 downloads
Adjustable Pier and Footing Pad
6219 downloads
Batter Symbol parametric
linebased and parametric (Slope projection)
880 downloads
Bobcat Skid-Steer Loader
Modeled in Revit
Site Equipment, Loader, Entourage.
2698 downloads
Bulldozer
Bulldozer
3.5 Stars from 6 Votes
6460 downloads
CAT 988H Large Wheel Loader
4.5 Stars from 3 Votes
7356 downloads
Concrete Pier Block
Concrete Pier Block
Revit 2018 Concrete Pier Block_parametric
1628 downloads
Flowers
Bunch of flowers to "plant" or place in a vase
12039 downloads
Gabion
Gabion
Parametric Gabion, Uses a model hatch pattern to show the stone work.
4 Stars from 5 Votes
15374 downloads
Gabion Wall Block 2' by 2' by 1'
for gabion walls, allows light to penetrate through
(a la Herzog+de Mueron's Napa Winery)
4 Stars from 3 Votes
18139 downloads
Gabion-Cranked
Gabion-Cranked
Gabion with a parametric crank, two lengths and an Angle
5051 downloads
GM sign
GM sign
Highway sign for GM
982 downloads
Grading Spot Elevation Symbol
landarchBIM.com
Generic Spot Elevation Marker (Generic Annotation/ Symbol) for grading plans.
More information on this object.
1633 downloads
HeliPad
HeliPad
A helicoptor landing pad for a Bell 412 Commerical Helicoptor. Paved FATO and TLOF, inside fenced area.
2 Stars from 2 Votes
10212 downloads
Isoras rojas
Isoras rojas
4.5 Stars from 4 Votes
16028 downloads
Museum Dino Sculpture
3 Stars from 8 Votes
8726 downloads
Parametric Sand Dune
https://en.wikipedia.org/wiki/Barchan
549 downloads
pavers circular plan
400 SQ x 50mm deep Pavers. The pavers are laid in rows following circular paths from a common radius. The extent of the paver rows can be edited.
1871 downloads
PLANT PLANTA
PLANT PLANTA
54808 downloads
Scalable Snowman
Scalable Snowman
Product Version: Revit Architecture 2019
375 downloads
Soldier Pile
Soldier Pile
437 downloads
Soldier Pile - Soldier Centered
539 downloads
Soldier Pile - Soldier Offset
586 downloads
Soldier Pile V2
Soldier Pile V2
Updated the soldier Pile to include a pile offset from center of hole - for applications close to propertylines
423 downloads
Stacked Rock Retaining Wall Baluster
What is revit bad at? Sitework. What else is revit bad at? Railings.
So here's a lovechild of revit's two weaknesses that's actually somewhat powerful--A baluster of stacked rocks that tessalates to form a retaining wall.
With revit 2018's new feature that allows railings to follow topography, You can place a railing on smoothly-graded surfaces like paths and roadways and use this baluster on a 4'-8" spacing to achieve a decent, low-effort look.
Enjoy. Improve the rocks at your leisure.
EDIT: This is a BALUSTER which is a component within a railing. Take a default railing, switch out the posts/balusters for this at a 4'8" spacing.
4.5 Stars from 7 Votes
10016 downloads
Succulent/Aloe Plant 2D - Variable sizes + pot
2D Succulent plant with paramters that allow 2ft, 4ft & 6ft diameters, along with a pot visibility option for each size.
1766 downloads
Page generation time: 0.6966
