Distance from ceiling and materials - parametric. |
59242 downloads
No rating |
Product Version: Revit Building 9.1
5862 downloads
1-Gang Outlet (General Usage) w/ electrical conduit connector. |
6130 downloads
1-Gang Outlet & 1x15A for Telephone (Combined in one plate). |
Product Version: Unknown
4865 downloads
1-Gang Single Pole Switch (w/ electrical conduit connector) |
7918 downloads
Edited for particular job configuration with adjustable day tank option. |
Product Version: Revit MEP 2012
8119 downloads
Simple lamp made from an flat surfaces and lines. Perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator. |
3374 downloads
No rating |
1477 downloads
So I got this object from another user (I think it is japalvarez03's, hope he/she doesn't mind hehe), and edited it to make it three in one: dobule gang outlet, ethernet outlet and TV outlet. The symbols change accordingly. |
No rating |
447 downloads
No rating |
266 downloads
2 Tier Glass Chandelier
Lights Only Work Rendered |
22545 downloads
2-Gang Outlet (w/ electrical conduit connector) |
10855 downloads
2-Gang Single Pole Switch (w/ electrical conduit connector) |
7858 downloads
Simple lamp made from flat surfaces and lines. Perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator. |
No rating |
2254 downloads
200AMPSERVICEPANEL WMAST |
3984 downloads
Pedigo floor pedestal. Two sizes available. |
No rating |
1476 downloads
This Family combines a fully realistic renderable Outlet and the capabilities of a MEP Family. Each Receptacle can be scheduled and tied to in MEP.
No rating |
2310 downloads
220 Outlet symbol |
No rating |
4559 downloads
3 lamp strip fluorescent |
No rating |
21321 downloads
Chandelier with adjustable height and slope for ceiling. Has 3 individual light sources. User may need to adjust the lighting parameters for rendering. RAC2012 |
32984 downloads
3-Gang Switch (2 Single Pole Switch; 1 3-Way Switch) w/ electrical conduit connector |
11002 downloads
3-lamp stainless steel ceiling mounted track light |
47945 downloads
30KVA Power plant GRN |
No rating |
702 downloads
30KVA Mikano Green color power generator |
No rating |
1467 downloads
This is a generic 32 track Mixing console with ballparked sizing |
No rating |
1875 downloads
Model off of the Mark Architectural Lighting Magellan Series. Very Detailed |
19084 downloads
No rating |
Product Version: Revit Systems 2
1463 downloads
BASED ON HISTORIC LIGHT FIXTURE. LIGHT SOURCE NOT ACTUALLY INSIDE GLOBES. LENGTH CAN BE ADJUSTED. |
40271 downloads
5 way switch Decora style Light switch |
No rating |
2977 downloads
Parametric Materials. |
No rating |
1017 downloads
