60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 3 | 1 | 2 | 3 Next >>
Abrigo de Sobrepor para Mangueiras/Hidrante - Fire Hydrant
Abrigo de Sobrepor para Mangueiras/Hidrante - 75x45x17.
2753 downloads
Ansul Pull Station
Ansul Pull Station
Wall mounted Ansul Pull from the R-102 Fire Suppresssion System. Can be either flush mounted or mounted with the conduit running outside of the wall. The conduit has an parameter allowing you to enter the height of the ceiling above for it to die into. Mounts at 4'-0" AFF (standard).
4165 downloads
Automatic Fire Extinguisher
Automatic fire extinguisher 11 kg to 44 KG
Product Version: Revit MEP 2015
1346 downloads
Boca de Incendios Combinada
Hidrante con Nicho y extintor AVC (incluye simbolo)
5 Stars from 2 Votes
Product Version: Revit Structure 2017
1460 downloads
Ceasefire - CFP96
Ceasefire - CFP96
Download here:
bimcatalogs.partcommunity.com/3d-cad-models/sso/cease-fire-cease-fire-cease-fire?info=ceasefire%2Fcease_fire_asmtab.prj
Feedback welcome :-)
739 downloads
Ceiling Based Sprinkler
rate, share and enjoy..
Product Version: Revit Structure 2009
4141 downloads
Central de alarme de incêndio endereçável - Central Fire Alarm
Central de alarme de incêndio endereçável. Baseada no modelo CIE 2500 da Intelbras.
4.5 Stars from 3 Votes
2156 downloads
CT-Fire Hose Cabinet (FHC)
Fire Fighting equipment- Fire Hose Cabinet (FHC) fully parametric with pipe inlets.
4.5 Stars from 2 Votes
7005 downloads
Emergency Light Wall Round
Product Version: Unknown
911 downloads
298 downloads
Exit Sign - Annotation Only
This is an Exit Sign I made, it has all arrows and filled regions for which ever side you need it on (Top, Right, Bottom, Left). All of which are on instance parameters and is very easy to use. ...very easy to use.
3 Stars from 2 Votes
2820 downloads
Extintores de Parede - Fire Extinguisher
Dois modelos: PQS e CO2 fixados na parede.
4393 downloads
Fire Alarm Pull Station Box
A Non-Hosted Fire Alarm pull station, Red box with White Lettering, set at 3' - 6" AFFL
12484 downloads
Fire Blanket housing
Basic fire blanket housing
1660 downloads
Fire Bucket with Stand
Product Version: Revit MEP 2017
436 downloads
Fire Bucket with Stand wall Mounted
280 downloads
Fire Department Connection 2 way
1539 downloads
Fire Department Inlet Connection - 3 Way - Body.rfa
Product Version: Revit MEP 2009
2715 downloads
Fire Department Standpipe Connection
Standpipe connections for the Fire Department, Non-hosted, Parametric - Comes in 2 & 4 Pipe connections. Idealy through the wall of the building to street side
4 Stars from 1 Votes
5219 downloads
Fire Emergency Proceedure Board
This is a Fire Emergency Proceedures board used at supermarket fuel stations in New Zealand, modelled pretty close to requirements.  Generic Model - not hosted, non-parapemtric.
Key words;  Gas Station, Petrol Station, Fuel Station, Service Station.
10155 downloads
fire extinguisher (CO2)
My first up load
No host can place any location. It alway height 1 m from ref plan. In plan you will see as symbol but in section&3D view will see all tank. Please coment after used.
Product Version: Revit MEP 2010
11036 downloads
Fire Extinguisher Box
Fire Extinguisher made in Revit 2014.
  • Adjustable Height
  • Pipe Connectors
  • Standard Dimensions
This is my first uploaded family so I hope you Like it. take a look at www.incide.it
12580 downloads
Fire Extinguisher Cabinet
Adjustable fire extinguisher cabinet with three embedded types: surface mounted, semi-recessed, or recessed.
2.5 Stars from 5 Votes
14697 downloads
Fire Extinguisher Cabinet - Hosted w/Vision Panel
Wall Hosted Fire Extingusher Cabinets, one with Glass Vision Panel and one without (Inside the same familiy)
9581 downloads
Fire Extinguisher Cabinet - Non Hosted
Stainless Steel Non-Hosted Fire Extingusher Cabinet, Parametric for Sizes
6971 downloads
Fire Extinguisher-Quell
23777 downloads
3.5 Stars from 3 Votes
9092 downloads
FIRE HOSE REEL
FIRE HOSE REEL
FIRE SERVICES
15178 downloads
FIRE HOSE REEL
FIRE SERVICES
1768 downloads
FIRE HOSE REEL
FIRE SERVICES
1423 downloads
Page generation time: 0.6473
