No rating |
Product Version: Revit Structure 2009
3629 downloads
10 - Toilet Accessory - Sanitary Napkin Disposal |
Product Version: Revit Building 9
20122 downloads
This was done with the railing tool. Super clean and easy to use. Copy from the RVT file to your Project. If you get ambitious, add some piles and a no tresspassing sign.
NOTE:
You may need to adjust the material to ensure it looks correct. The chainlink is a model line drafting hatch.
Also, if you change the height, you will need to adjust the 'Chainlink Fence Panel' Profile to suit.
Good Luck - RFB |
15084 downloads
Non-Parametric Monitor family |
No rating |
Product Version: Unknown
1492 downloads
20ft Shipping Container - With Parametric settings for the Doors open or close them.
tried to make this as close to accurate as possible.
Revit 2014 - 64 bit |
42312 downloads
Vanity bracket that holds skirt |
No rating |
304 downloads
2x2 square table with parametric height |
1474 downloads
3 Bike racks by Barco Products
http://www.barcoproducts.com/store/index2.asp?DEPARTMENT_ID=156
Modelled in Revit 2012 |
11027 downloads
Ortal Space Creator 3-Sided fireplace. 2 long glass sides, 1 narrow. Included options for 3 sizes, fully parametric. |
3230 downloads
No rating |
Product Version: Revit Building 9.1
1767 downloads
Here's an adaptive component that generates a 2" diameter rail through 8 movable points set by the user.
You have to hit TAB to select the adaptive points in order to get the XYZ grips. |
No rating |
2236 downloads
No rating |
645 downloads
These files are based on 3Form Panels and 3Form Suspend Solutions Hardware. These files are meant to be used together and placed into the Project Environment. The Panel can be customized in width and height (Note that 3Form panels are typically 4'-0" wide by 8'-0" high maximum) and is placed by the centerline in height to coordinate with the suspension system parameters. The hardware suspension system has adjustments for overall height and the panel centerline height to move the clips up and down. The clips can be switched from center clips to end clips and the bottom attachment can be changed from floor mounted to wall mounted as well. NOTE: THIS DOWNLOAD ONLY DOWNLOADS THE PANEL. THE SUSPENSION SYSTEM IS A SEPARATE DOWNLOAD. |
7730 downloads
These files are based on 3Form Panels and 3Form Suspend Solutions Hardware. These files are meant to be used together and placed into the Project Environment. The Panel can be customized in width and height (Note that 3Form panels are typically 4'-0" wide by 8'-0" high maximum) and is placed by the centerline in height to coordinate with the suspension system parameters. The hardware suspension system has adjustments for overall height and the panel centerline height to move the clips up and down. The clips can be switched from center clips to end clips and the bottom attachment can be changed from floor mounted to wall mounted as well. NOTE: THIS DOWNLOAD ONLY DOWNLOADS THE SUSPENSION SYSTEM. THE PANEL IS LOCATED IN A SEPARATE DOWNLOAD. |
No rating |
3993 downloads
these can used for bag showrooms or can b downloaded for purposes like for residences or ne other useful needs... so enjoy |
No rating |
2635 downloads
4 Point Shade Sail |
16209 downloads
Caster Whell (50mm) for furniture - Revit 2021 |
1838 downloads
6196 downloads
Top width: 14"
Bottom width: 22" |
2008 downloads
Product Version: Revit Structure 2015
1508 downloads
No rating |
2286 downloads
75mm Caster suitable for cabinets etc. |
7873 downloads
A Mirror that is used for smaller coimmercial bathrooms |
17022 downloads
NEEDED A CASKET FOR A PROJECT I WAS DOING. I DIDN'T SEE ANY ON HERE SO I MADE A VERY BASIC ONE. |
999 downloads
Someone you can trust |
991 downloads
No rating |
3727 downloads
Plastic rack for holding glass measuring vessels |
Product Version: Revit Building 8.1
1042 downloads
All signs are wall based and should be set at 5' A.F.F. at teh bottom of the bottom of the lowest text. |
5413 downloads
4363 downloads
Fully adjustable ADA grab bar for use in restrooms |
26578 downloads
