81 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
Column Panelboard
Column Panelboard
2.5 Stars from 2 Votes
Product Version: Revit Structure 2010
2093 downloads
Contactors Enclosed Non Combination
Product Version: Unknown
1239 downloads
Eaton Electrical Vehicle Charger Pedestal Type
2810 downloads
Eaton Electrical Vehicle Charger Wall Mounted
2996 downloads
Eaton model TP1 Energy Efficient Transformers
http://www.eaton.com
NEMA TP-1 transformers are typically installed in commercial construction, as well as in educational (K–12 and universities), government and industrial facilities. NEMA TP-1 compliant transformers are especially designed to have low no-load (core) losses.
1522 downloads
Enclosed Circuit Breakers
Eaton’s enclosed circuit breakers offer all the advantages and accessories of a circuit breaker packaged in an enclosure for nearly any application requiring a means of disconnect. Ideal for a variety of locations including general purpose, rainproof surface mounting, water and dustproof, dustproof surface mounting, and hazardous locations.
4154 downloads
MCC Corner Section
MCC Corner Section
MCC corner section. Revit 2022.
68 downloads
MCC Face Plate - ATS
MCC Face Plate - ATS. Revit 2022.
48 downloads
MCC Face Plate - Feeder Breaker
MCC Face Plate - Feeder Breaker. Revit 2022.
82 downloads
MCC Face Plate - Feeder Breaker - Half Left
MCC Face Plate - Feeder Breaker - Half Left. Revit 2022.
39 downloads
MCC Face Plate - Feeder Breaker - Half Right
MCC Face Plate - Feeder Breaker - Half Right. Revit 2022.
50 downloads
MCC Face Plate - Main Disconnect
MCC Face Plate - Main Disconnect. Revit 2022.
51 downloads
MCC Face Plate - PQM
MCC Face Plate - PQM. Revit 2022.
74 downloads
MCC Face Plate - SPD
MCC Face Plate - SPD. Revit 2022.
40 downloads
MCC Face Plate - Transformer
MCC Face Plate - Transformer. Revit 2022.
62 downloads
MCC Face Plate - VFD
MCC Face Plate - VFD. Revit 2022.
48 downloads
MCC Face Plates
MCC Face Plates
*OLD*
Was not aware that you cannot upload multiple files. Please refer to new uploads.
Product Version: Revit MEP 2020
302 downloads
MCC Panel and Xmer Section
MCC typical panel and transformer section. Revit 2022.
139 downloads
MCC Section
MCC Section
MCC Section for use with faceplate families. Revit version 2022.
63 downloads
MCC Section
MCC Section
*OLD*
702 downloads
MCC Section and Face Plates
*NOTE* Was not aware that you cannot upload multiple files. Please refer to new uploads of each individual family. *NOTE*
Updates: Families modified from previous upload based on usage to improve usability and correct parameters based on Eaton Design Guide.
119 downloads
Motor Starter Enclosed Full Voltage Non Reversing
623 downloads
Motor Starter Enclosed Full Voltage Reversing
511 downloads
Motor Starters Enclosed Non Combination
819 downloads
PRL1a Panelboard
PRL1a Panelboard
1300 downloads
PRL2a Lighting Panelboard
4 Stars from 1 Votes
1126 downloads
PRL3a Panelboard
PRL3a Panelboard
752 downloads
PRL4 Panelboard
PRL4 Panelboard
944 downloads
Safety Switches
Safety Switches
Safety switches have a number of applications from service entrance to branch circuit protection. They are also horsepower rated for use as motor circuit switches.
2711 downloads
Single-Glass 1.rfa
Single-Glass 1.rfa
Single-Glass 1.rfa
4 Stars from 2 Votes
2357 downloads
Page generation time: 4.2969
