Wed, May 11, 2016 at 10:24:39 PM
Joined Thu, Mar 3, 2016
How do I use it?
Wed, Feb 22, 2017 at 3:38:50 PM
Joined Wed, Feb 22, 2017
hola disculpa como aplico esta familia
Wed, Feb 22, 2017 at 3:38:51 PM
Sat, Apr 22, 2017 at 12:29:06 PM
Joined Thu, Mar 22, 2012 No rating This user is offline |
HOLA , YO EN REVIT 2015, ESTANDO EN UNA VISTA 3D LE DI LA OPCION DE INCERTAR UN COMPONENTE LUEGO PUSE EL CURSOR EN LA CUBIERTA CREADA ANTERIOR MENTE Y LE DI COLOCAR CON CLICK IZQUIERDO DEL MOUSE. AL COLOCARLAS EL CUIDADO QUE HAY QUE TENER ES DEPENDIENDO DEL GROSOR DE LA CUBIERTA . A MI ME FUNCIONO ASI . ATT ediergonzalez25@gmail.com
Wed, Jul 18, 2018 at 7:49:32 PM
Joined Tue, May 2, 2017
GRACIAS POR TU APORTE
Sun, Aug 5, 2018 at 1:12:35 AM
Joined Sun, Aug 5, 2018 No rating This user is offline |
Perfect!, thank u so much
Fri, Aug 9, 2019 at 3:51:13 PM
Joined Wed, Jul 8, 2015 No rating This user is offline |
Se crea una cubierta normal y luego sobre ella se colocan las planchas. Despues se oculta la cubierta normal, para que se vean solo las laminas.
Mon, Apr 20, 2020 at 10:37:32 PM
Joined Sun, Feb 9, 2020
Muchas gracias por este aporte
Mon, May 25, 2020 at 7:05:45 PM
Joined Mon, May 25, 2020 No rating This user is offline |
Hola! alguien sabe como coloco las planchas sobre la cubierta ?
Sat, Mar 23, 2024 at 6:15:40 PM
Joined Thu, Aug 11, 2016 No rating This user is offline |
Gracias a todos los que dejaron las instrucciones para colocarlos.
