48 Users Online (46 Members):
Picture Frames
45460 Downloads
![4.5 Stars from 20 Votes](/images/stars_4.5.gif)
![](images/spacer.gif) | ![Picture Frames](object_docs/8497.jpg)
5 picture frame profiles in family. Turn on/off 2 layers of matting as well as 45 degree cut. Turn on/off image surface (depth can change depending on how many/if you have matting on). Frame dimensions are dynamic and parameters set to vary amount of matting around the picture. Please rate! :-) |
CSI Division: 12 10 00 Art RevitCity Division: Furnishings > Miscellaneous > Frames
Uploaded By: Budtooz22
Uploaded On: Tue, Jan 26, 2010
Tue, Feb 16, 2010 at 5:24:01 PM
Joined Sun, Oct 11, 2009
![4.5 Stars from 3 Votes](/images/stars_4.5.gif) This user is offline |
how did you put the picture on the frame?
Wed, Jul 7, 2010 at 4:38:27 PM
Joined Fri, Apr 16, 2010
![5 Stars from 1 Votes](/images/stars_5.gif) This user is offline |
Thank you :-)
Sun, Oct 17, 2010 at 8:15:04 AM
Joined Thu, Jul 2, 2009
![5 Stars from 2 Votes](/images/stars_5.gif) This user is offline |
Nice! 5 points
Fri, Apr 13, 2012 at 3:21:54 PM
Joined Fri, Nov 4, 2011 No rating This user is offline |
Thanks, desiging a meuseum and this works great!!!
Mon, Jul 23, 2012 at 8:22:21 AM
Joined Wed, Jun 18, 2008
![3.5 Stars from 3 Votes](/images/stars_3.5.gif) This user is offline |
i hevnt used it yet but sounds very complex. if it works congratulations on a great design
Sat, Nov 24, 2012 at 11:55:48 PM
Joined Fri, Nov 23, 2012 No rating This user is offline |
How do you put a image in the frame?
Thu, Jan 24, 2013 at 11:31:12 AM
Joined Fri, Apr 22, 2011
![4 Stars from 1 Votes](/images/stars_4.gif) This user is offline |
Finally! Someone made a great parametric picture frame with matting - great job & thank you!
Tue, May 28, 2013 at 1:24:30 PM
Joined Mon, May 20, 2013
Members: | 2015328 | Objects: | 22942 | Forum Posts: | 152202 | Job Listings: | 3 |
