Carrier Air Handling Unit - Inverter - Small
13419 Downloads
Modeled from Carrier air conditioning inverter dimensions & appearance. May be of use in showing air con plant in residential or light commercial applications. |
CSI Division: 42 Process Heating, Cooling, & Drying Equipment RevitCity Division: Equipment > Miscellaneous
Uploaded By: Johnboy
Uploaded On: Mon, Jun 29, 2009 Original Creator: Johnboy
Thu, Sep 9, 2010 at 6:48:34 AM
Joined Thu, Sep 9, 2010
Hi, friend what a nice comment. the need for FRESH AIR Ventilation is very acute to live healthy in such air tight dwellings! Energy experts often quote the axiom, "SEAL TIGHT, VENTILATE RIGHT" as their recommended approach to house ventilation. Thanks
Wed, Dec 10, 2014 at 4:52:54 PM
Joined Tue, Nov 18, 2014
Well Kronny, you can go curse yourself with your big curse words dipshit
Sat, Oct 3, 2015 at 11:39:18 AM
Joined Sat, Oct 6, 2012
thanks
Tue, Apr 26, 2016 at 3:47:58 AM
Joined Thu, May 1, 2014
Re-applied materials and it is all good.
Thank you to the uploader for sharing :-)
Mon, Jan 29, 2024 at 6:09:10 AM
Joined Tue, Jan 16, 2024 No rating This user is offline |
Paper代写的优势是什么?首先, Paper代写可以帮助学生提高他们的学术成绩。代写服务通常由经验丰富的写手提供,这些写手拥有高水平的写作技巧和知识。
Members: | 2097359 | Objects: | 23163 | Forum Posts: | 152288 | Job Listings: | 3 |
