Tue, Mar 4, 2008 at 1:16:22 AM
Joined Sat, Feb 23, 2008
Hey, This is great, but I have one question? How do I show this same elevator core/shaft to have a opening on every level on a multi-story building without having to place this one elevator family object on every level? Because I have a section that cuts through the elvator core/shaft and it shows more than one elevator in the core/shaft. thanks, ireyes
Wed, Jul 23, 2008 at 10:30:51 AM
Joined Wed, Apr 2, 2008
I had to modify it and make 2 different ones. One with only the doors and symbolic lines and one that is the complete model to put on the bottom floor.
Tue, Aug 10, 2010 at 2:43:53 PM
Joined Tue, Jul 27, 2010 No rating This user is offline |
thanks
Tue, Dec 14, 2010 at 12:00:09 PM
Joined Fri, Nov 12, 2010 No rating This user is offline |
I, being a revit noob, just put multiple elevators in the same shaft giving an illusion of one complete elevator shaft.
Mon, Oct 1, 2012 at 10:45:51 AM
Joined Tue, Sep 25, 2012 No rating This user is offline |
If you modify it how can you load it back into the project without changing the original in the project...?
Thu, Nov 1, 2012 at 11:35:05 PM
Joined Tue, Feb 28, 2012
If corvax ever sharted would he die because of dylan?
Mon, Apr 22, 2013 at 2:46:32 PM
Joined Thu, Apr 18, 2013 No rating This user is offline |
Het Revit noob....
Tue, Dec 17, 2013 at 8:02:35 AM
Joined Mon, Oct 7, 2013 No rating This user is offline |
balls
Thu, Mar 6, 2014 at 10:15:38 AM
Joined Thu, Mar 6, 2014 No rating This user is offline |
HEY BOYS TY FOR ELEVATOR
Tue, Apr 8, 2014 at 12:42:40 PM
Joined Fri, Dec 6, 2013 No rating This user is offline |
its an amazing fit to my deign but how do you rotate it?
Wed, Oct 17, 2018 at 2:31:11 PM
Joined Thu, Oct 11, 2018 No rating This user is offline |
Does someone have only the door part of this model? I dont know how to edit the model myself lol
Thu, Dec 24, 2020 at 2:50:29 PM
Joined Mon, Nov 23, 2020 No rating This user is offline |
Being new to Revit (litterally started a few months ago), I placed down the elevator on the basement level (I gahterd the idea from the posts of nac23 and Tredding), but do I put the same elevator model above that in the shaft? Do I need to modify the model to put it correctly or can I download a model that is correcct?
