22 Users Online (21 Members):
Freight Elevator
37482 Downloads
![4.5 Stars from 5 Votes](/images/stars_4.5.gif)
![](images/spacer.gif) | ![Freight Elevator](object_docs/3641.jpg)
Freight Elevator |
CSI Division: 14 20 00 Elevators RevitCity Division: Equipment > Conveying
Product Version: Revit Building 9.1 |
Uploaded By: AEckerson
Uploaded On: Wed, May 9, 2007
Wed, May 9, 2007 at 3:14:57 PM
![AEckerson Avatar](user_avatar/28119.jpg)
Joined Thu, Jan 11, 2007
![3.5 Stars from 5 Votes](/images/stars_3.5.gif) This user is offline |
This old freight elevator can be customized in the following ways: All materials are parametric Height between floor levels can be changed The location of the platform can be controlled and the cable/weights adjust themselves Width, Height, and Depth of the Framework probably shouldn't be adjusted. There are parametric controls for these dimensions, but the gears and belts will probably get out of alignment.
Tue, Feb 12, 2008 at 3:23:43 PM
Joined Thu, May 25, 2006
![3.5 Stars from 3 Votes](/images/stars_3.5.gif) This user is offline |
This is wall based and will only set the elevator so that the wall is right thru the middle of the elevator.
Thu, May 20, 2010 at 3:56:29 PM
It is actually FLOOR-based. The elevator is hosted on the "top floor" and you can control how far down it goes.
Fri, Dec 16, 2011 at 9:44:48 AM
Joined Tue, Nov 15, 2011 No rating This user is offline |
Very good.
Thank you for your upload
Mon, Apr 22, 2013 at 2:42:07 PM
Joined Thu, Apr 18, 2013 No rating This user is offline |
yup
Thu, Sep 19, 2013 at 4:18:12 PM
Joined Tue, Nov 8, 2011 No rating This user is offline |
Great simple lift. Exactly what i needed for my dealership (parts lift)
Fri, Sep 20, 2013 at 3:11:48 PM
i meant to highlight the point to other users that you place this componenets on the highest level and it offsets downward. I kept trying to place it on main floor like i did with other elevators i tried
Members: | 2020338 | Objects: | 22957 | Forum Posts: | 152190 | Job Listings: | 3 |
