SIMES S.P.A. - BLITZ 4 WINDOWS - wall surface outdoor lighting fixtures
981 Downloads
BLITZ 4 WINDOWS
Art. S.4089W 1 MODULES COB 3000K 220-240Vac 1867lm 17.4W CRI 90 MacAdam step 3Rated luminaire luminous flux: 303lmRated input power: 18.1WLuminaire efficacy: 17lm/WElectronic ballast ON/OFF not dimmable CELUMINAIRE TYPEWall mounted luminaire. IP rating IP 65MATERIAL CHARACTERISTICSAluminium die cast housing in EN AB-47100 (low copper content) with high resistance against corrosion. Stone wash surface treatment prior to painting process. A4 grade Stainless Steel screws with 2,5-3% molybdenum content which increases the resistance against corrosion. Silicone gaskets. Painting Process : 3 Step Process1) Surface treatment with BONDERITE. A heavy metal free chemical surface treatment containing ceramic nano particles giving a cohesive, inorganic and highly dense protective coating. 2) PRE POLYMERIZATION a process of introducing an epoxy primer with excellent characteristics to the paint which also offers very high resistance to oxidation due to its Zinc content. 3) POLYMERIZATION a process with the application of polyester powder with high resistance against UV rays and harsh weather conditions. Resistance test protection for Marine applications for 1200h. Mechanical resistance IK 10LIGHTING PERFORMANCELuminaires come with toughened glass lenses already installed using the appropriate "lens-carrier slide". These may be substituted with coloured dichroic lenses. INSTALLATION AND MAINTENANCEA robust, die-cast aluminium cap is secured to the base with four stainless steel screws. WIRINGDouble cable entries with PG13,5 (Ø 7÷12 mm) cable glands. Isolation: CLASS I . Available colours: Aluminium grey (cod.14). Weight: 3.9 Kg Glow Wire test: 850°CLED circuit included.This luminaire contains built-in LED modules. In case of damage or malfunction please contact the manufacturer to receive additional instructions on how to replace and relative spare parts to order. The LED modules cannot be handled in the luminaire by the end user.LED modules are engineered accordingly to the existing regulations of Lumen Maintenance (LM80) and Technical Memorandum (TM21), where uniformity and quality of the light is 70,000 hours referred to L80 B10 Ta 25 ° C (50,000 hours referable to L80 B10 Ta 40°C). Lifespan of the luminaire > 50,000 hours at 40°C. Performance Ambient temperature Tq 25°C. Operating ambient temperature range is from -20°C to +50°C. Storage temperature range from -20°C to +60°C. |
CSI Division: 26 56 00 Exterior Lighting RevitCity Division: Electrical > Lighting > Exterior
Product Version: Revit Architecture 2018 |
Uploaded By: SIMES
Uploaded On: Tue, Nov 23, 2021 Original Creator: SIMES S.P.A.
