97 Users Online (95 Members):
Generic round surface mounted or recessed light
4377 Downloads
![4 Stars from 1 Votes](/images/stars_4.gif)
![](images/spacer.gif) | ![Generic round surface mounted or recessed light](object_docs/22249.jpg)
Minimalist generic round downlight/uplight/wall light
Why this lamp?
* mounts on all surfaces (ceilings, floors, walls, objects, etc.)
* optional lens and diffusor
* recess parametrizable (any distance from surface, incl. surface mounting)
* diameter and depth scalable in large ranges (depth down to 20 mm!)
* realistically rendering (metal reflector, dimmed diffusor when lamp off)* minimalist design
* all parameters thoroughly documented
* no junk parameters, well almost… :) |
CSI Division: 26 51 00 Interior Lighting RevitCity Division: Electrical > Lighting > Recessed Cans
Product Version: Revit Architecture 2020 |
Uploaded By: matthiaswolffgr
Uploaded On: Sun, May 9, 2021 Original Creator: Matthias Wolff
Sat, May 15, 2021 at 9:38:26 AM
Joined Sun, Dec 2, 2012 No rating This user is offline |
This family appears to be saved in Revit 21 and doesnt open in 20. Do you have your original in 20 you can post?
Thu, Jun 10, 2021 at 5:35:00 PM
Joined Fri, Jun 22, 2018 No rating This user is offline |
Holaa como estas? Tengo RVT 2021 y no me deja agregarlo ni aun asi, tendras una versión inferior, por fa?? Gracias ![Smile](/images/smiles/smile.gif)
Wed, Jul 20, 2022 at 12:01:25 AM
Joined Wed, Mar 16, 2016 No rating This user is offline |
tengo 2021, y dice que esta en una posterior osea 2022 0 2023.. que raro este archivp fue subido en 2021. podrias subirlo nuevamente y seria util aclarar a version. saludos
Wed, Jul 20, 2022 at 12:03:44 AM
ya vi!!! si esta en 2022!!! en la vista previa de abri archivo en revit siempre indica version en efecto es 2022..
Fri, Oct 7, 2022 at 9:14:39 AM
Joined Thu, Dec 10, 2020 No rating This user is offline |
I have revit 2021 and it says it was created in a later version. Please upload the earliest year version you are able.
Members: | 2019003 | Objects: | 22958 | Forum Posts: | 152183 | Job Listings: | 3 |
